Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 11-23-2004, 08:50 PM
matt11583 matt11583 is offline
5.0 stang vs. lt1 camaro vs. 300zx turbo
which one of these cars would be the best all around car? i want to kno for reliability, handling, top end speed, acceleration, fun to drive ect.... i kon that they all have their ups n downs but which one would be the best overall...
Old 11-23-2004, 09:20 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: 5.0 stang vs. lt1 camaro vs. 300zx turbo
Reliability-As long as you take care of it...
Handling-Probably the 300zx
Top Speed-Camaro. 161mph
Accel-300 again?
I'd have to say that the camaro would be the most fun, which that could be considered a bit biased.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-23-2004, 09:55 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
The 300ZX should take the cake in acceleration, handling, and all-around performance, but it's gonna cost a lot more (and I'm talking mostly maintenance costs here) than an LT1 Camaro. They're both a pain in the ass to work on, but they're both fairly reliable if you take care of them. I'd say go for the 300ZX if you have the money for it; otherwise, stick with the LT1.
Old 11-24-2004, 01:28 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
with kman...
eventhough i didnt know the lt1 camaro's top-speed is 161mph...is that the computer's limiter or is there no limiter?
ZedEx Crew Member #4
Old 11-24-2004, 04:12 AM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
I believe they are limited to 155mph.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 11-24-2004, 06:21 AM
Z Cars Fanatic
well in that case, i am pretty sure that the Twin Turbo is limited to 155 also.
Old 11-24-2004, 10:16 AM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
That's easily corrected
Yours truly,
Gabriel
Old 11-24-2004, 07:59 PM
Z Cars Fanatic
oh yeah...remove the limiter and you can burry that needle.
Old 11-24-2004, 09:17 PM
how much maintance is a 300zx gonna take???
Old 11-25-2004, 12:31 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Depends on how much previous maintence the car has had (remember that they were last built stateside in 1996) and how much you plan to whip on it. The VG motor beefed to an extreme and even the twin turbo engines can easily last into the 200k mile range. But they usually don't because some retard decides its a good idea to run it to redline off every stoplight after turning the boost up to the bleeding edge of the stock fuel injectors ablities. Then they don't change the oil for a year. Stupid people kill cars.
Anyway, a clean VG30DETT isn't really that hard to find and requires little maintence, more than a Honda or something but its a performance engine so its expected. The rest of the car is just as stout and aside from normal wear and tear items like clutches and brake pads, its pretty good on maintence.
But as you can see \/ I may be more than a little biased here.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 12-10-2004, 04:14 AM
ForceFed300zx ForceFed300zx is offline
This is an easy question. The Z will be the easiest to get crap loads of power out of. It already has turbos and lower compression. Swap out the turbos, some big injectors, new ecu. You can get well over 500 rwhp. Lets face it, there is nothing like japanese reliability. Chevy and ford are junk. My Dad is a big fan of domestics and he spends more time working on them than racing them. The Z will out accelerate, out handle, and the ecu upgrade I talked about gets rid of the governor. Don't waste your time on trying to get those other pieces of junk fast. Go with the proven engineering of the Z. I have three and I personally believe they are the best cars every built. I built an 11 second car for 7 thousand dollars!
Old 12-10-2004, 06:58 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
You could build a 10 second car out of the 5 liter for 7k, that's including the price of the car...
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 12-10-2004, 01:39 PM
kman10587's Avatar
I personally agree with you somewhat, but I'd advise you to cut that shit out before you get banned.
Old 12-10-2004, 01:43 PM
Andydg Andydg is offline
Re: Re: 5.0 stang vs. lt1 camaro vs. 300zx turbo
I've seen that done before, 5.0's have a lot of cheap potential from what I've seen.
Old 12-10-2004, 07:49 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
I promise you 7 grand will go much farther in the LT1 and 5.0 than it will in the Z. The parts for both engines are limitless and very easy to get.
