Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-23-2004, 05:56 PM
gary407 gary407 is offline
3.8L engine will not accelerate
3.8L engine in 1988 Ford Thunderbird, will not accelerate when the throttle is advanced... new tps didnt help.. it just gasps for air...but it will set and idle perfectly...any ideas....???
Old 11-23-2004, 07:48 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: 3.8L engine will not accelerate
did you mean that it doesnt move at all, or it rolls forward at idle speed only?
Old 11-23-2004, 08:57 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
probably something with the transmission.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-23-2004, 10:15 PM
i mean that the engine wont increase in rpms..... there is nothing wrong with the transmission... this all happens with the car in neutral with the engine running....
Old 11-23-2004, 11:52 PM
so what exactly happens when you press the gas? what does it sound like? does it go forward in drive? backwards in reverse?
Old 11-24-2004, 08:20 AM
Re: Re: 3.8L engine will not accelerate
when the gas pedal is depressed the engine sounds like it is sucking air, but isnt getting gas...it will move in either direction if put in gear....
