need help with 97 Grand Prix
All my dashboard gauges are dead. The spedometer, odometer, tachometer, fuel gauge and water temp gauge. Also my tractioncontrol system will not turn on. The ABS light at ignition does not come on... however the rest of the car runs fine. ANy help or suggestions would be apprieiated. i checked all the under dash fuses already. HELP!!!!
Re: need help with 97 Grand Prix
Your body control module has probably gone bad. Check the connections to it and if that doesn't do anything then you will need to change the module out. You could get one from a wrecking yard to save some money. I'm not sure they are available in the aftermarket.
You said its a 97,but you left out,if its a S.E/GT or GTP
Thanks ~Larry~
![]() ClubGP Member 6530 Since 2001 |
