Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-23-2004, 04:14 PM
hondadude555 hondadude555 is offline
Funny smell coming from the car...:{
Hey guys, I think there might be a problem with my car. When ever I rev my engine up high to 5000 rpms or like that with the clutch in and the car standing in one place, then after couple of seconds there is this funny smell. I dont know if this is bad or not. It is not from the tires since the car stays in one place and doesnt move. SO i just rev the engine hard and then it starts to smell. I dont usually beat my car that bad and dont burn out a lot. Does anyone know where the smell is coming from and if this is bad and why it is happening? thanks a lot.
Old 11-23-2004, 05:18 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Funny smell coming from the car...:{
Does it happen to smell like rotten eggs? If so, your catalytic converter is going bad.
Old 11-23-2004, 05:31 PM
sort of, but not really. Im not absolutely sure of how rotten eggs smell, (im a dumass) but it sort of smells like burning rubber or something like that, (but i do not peel out, so it cant be the tires). If it is the catalic converter, is that serious, and would i have to replace it ASAP, and is it a serious thing to do? How do I know if it is the catalic converter?. thanks dude
Old 11-23-2004, 09:35 PM
caustic caustic is offline
Its probably the smell of burnt oil, preludes are known to burn oil in the VTEC range.
Old 11-23-2004, 10:53 PM
so what should i do? do i need to change the oil? hey guys a couple more things... Is it better if I switch to synthetic oil from the regular one i am using? whats the difference??
Old 11-23-2004, 10:55 PM
exman98 exman98 is offline
FIRST
Just keep putting more oil in, im not shure if youcan stop it
If you want to switch to synthetic you want to use semi synthetic oil then switch over to full synthetic on your next change. I have been told putting regular and full synthetic oil is practically like putting vegetable oil in water.
Old 11-23-2004, 11:04 PM
ok, thanks. Are there any other theories on why my car smells when i rev up my engine?
Old 11-24-2004, 04:08 AM
Enlightner Enlightner is offline
Ok ok. For starters when you're doing this do you have the car in gear with the clutch fully in?
H22as dont engage vtec if the cars in neutral maybe you're burning you're clutch. Ask someone to look at you're exhaust smoke when you do this then post back. You can tell by the exhaust smoke if you're burning oil.
Old 11-24-2004, 11:45 AM
ok thanks, Ill check for smoke. ALso, when i rev it up i sometimes let the clutch go a little so that the car inches up forward a little. IS this bad??
Old 11-24-2004, 05:21 PM
Gohan Ryu Gohan Ryu is offline
Re: Re: Funny smell coming from the car...:{
Revving up the engine then feathering out the clutch is the best way to launch a front wheel drive car. It's also a good way to burn out your clutch. Every time I launch hard with my Prelude I smell burnt clutch. My clutch is stock and it isn't built to launch like this - when it's time to replace it I'm gonna upgrade to stage 1 or 2.
Old 11-24-2004, 06:19 PM
hey, you know, it might be the clutch after all. I just might be burning out my clutch. NOw i realized what is going on. Thanks Gohan, u set me on a right way. Ill try to take it easy on the clutch.... or not and just replace it when it goes bad. lol. WHats a good kind of clutch that is durable, and is made for racing, or is there such a clutch?? thanks dudes!!!
Old 11-28-2004, 12:51 AM
joellthomas joellthomas is offline
Are you holding the revs at 5k? Why..
