Old 11-23-2004, 04:00 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
max output of turbo
can someone give me a direct link of the page i somehow came across last week that had like every mitsu. turbo and it stated their max HP and PSI that you could boost them to...i cant seem to find it today...thanks guys...sorry..i really just want to know mostly about the 13g/14b/16g's
Old 11-23-2004, 04:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: max output of turbo
use the seach bar at the bottom if you haven't already. search for "turbo horsepower" or "turbo ratings" or something like that. you're bound to find it eventually.
95 Talon TSI AWD
97 Eclipse GST
Old 11-23-2004, 05:33 PM
joemathews's Avatar
joemathews joemathews is offline
13g--not worth your time. Maybe 240 whp.
14b--some have squeezed out a little over 300 whp.
16g--depends on what kind you get...an EvoIII 16g has dyno'd just over 400 hp, but that car was practically maxed out with tuning, cams, VPC, etc.
What are your goals for the car? Decide that, then post a poll of what turbo you should put on.
1996 Eagle Talon
Old 11-23-2004, 05:47 PM
10.5sec92AWDTALON 10.5sec92AWDTALON is offline
I got 22-23 psi out of the 14b and ran 12.4@110 with a full weight 1992 Talon which is about 350 RWHP and about the max you'll get out of it, it's close to it's choke point and well out of it's ideal map area at that point. I also ran 11.7's with that car and a 16g which is around 380 HP and also about the max you'll get out of a regular 16g, it's again close to it's choke point and well out of it's ideal map area at that point.
Old 11-23-2004, 06:38 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
http://devnulled.com/archives/2004/0...dsm_turbos.php
Some estimate 10 horsepower per lb/min. A little less if you want to talk about all wheel horsepower.
Old 11-23-2004, 10:04 PM
i have a 92 auto(may 92...is that a def 7 bolt?)...obviously awd tsi...had a 13g rebuilt back when i drove my N/A(91)...so i replaced my slightly cracked 13g last weekend with my rebuilt 13g...i just would like an everyday car with maybe 300 hp range...now if i got a small 16g..would that bolt up with same manifold and all? or would a 14b? or both?...what should i do or plan on doing anyways?
boost gauge is being shipped now...and mbc this x mas..new belts soon..new tires in the spring...strut bars..UICP spring..intake spring
Old 11-24-2004, 10:06 AM
kjewer1 kjewer1 is offline
AF - Advisor
You most likely have a 6 bolt. In fact I would bet on it. But you can use the info on www.vfaq.com to check the oil pan shape and find out.
The 13g is damn small. If you are willing to buy a new turbo go straight to a EVO16g at the least. The prices new are very close. If you get a deal on a used one that is a different story. And if you are really on a budget, its hard to beat a used 14b for ~100 bucks But keep in mind the manifold and lines are different between the tdo5 turbos and the little 13g.
For 300 whp on pump gas I wouldnt go lower than a 16g based turbo, and would probably go with a 20g if you dont want to outgrow this turbo soon. Thats your call, and depends on your goals.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
