Old 11-23-2004, 03:35 PM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
change oil soon light
just today my change oil soon light started staying on for about a minute when i first start my car up. before when i would start my car up it would just comon for about 5 seconds (along with all the other lights) and quickly go off. i checked the oil, seems fine. my last oil change was about 2k miles ago, so its not due just yet. any ideas? 99 se 3800 82k miles
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 11-24-2004, 12:33 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: change oil soon light
OK blurr,
We told you not to use your Mothers cooking oil in your car anymore.
When you changed the oil did you reset "oil life". Part of the on board display. Go to oil life display, hold reset button for about five sec. should go back to 100%. See if light goes out.
Old 12-03-2004, 06:03 PM
ironmom ironmom is offline
I have had the same problem but mine started to do that as soon as I changed the oil. Where do I find the reset button for the oil.
Old 12-03-2004, 08:25 PM
What GP do you have?
Old 12-05-2004, 09:46 AM
GTPCatz GTPCatz is offline
Banned
IF the light flashes on for about a min then goes off this could also be the onset of a oil pump problem....if it was just time to change the oil it would stay on till you turned it off....
Old 12-06-2004, 07:03 AM
Re: Re: change oil soon light
[quote=GTPCatz]IF the light flashes on for about a min then goes off this could also be the onset of a oil pump problem...QUOTE]
an oil pump problem...will it have to be replaced?
Old 12-06-2004, 09:19 AM
Banned
yes...but Im just giving you worst case Scenario...
it could just be that you need to reset the light....I would start there first
Old 07-20-2005, 07:35 PM
quick thread revival! my change oil light has been stayin on for a min when i turn the car on since this post at least.. well today i went to get my CASE learn done cuz i got a DHP and vwalaa! doesn't do it anymore! oh yea and the dealer tried to charge me 90 bucks..what a freakin rip off! i got a local guy to do it for me.
Old 07-22-2005, 10:11 AM
jay69dogg jay69dogg is offline
To reset the "Change Oil Soon", you turn the key to the On position but do not start the engine. Press the accelerator 3 times in 5 seconds and the change oil light should start to blink. This shows that oil life monitor is resetting. Turn the car back to off. Next time you start your car, the "Change Oil Soon" light should only be on for a couple seconds. Remember to do this procedure every time you change your oil. This procedure is also in the owner’s manual.
Old 07-23-2005, 07:36 PM
crovax crovax is offline
jay69dogg is exactly right, that is if you do NOT have a reset botton on your DIC
160 stat/ STB/ FWI with K&N/ Pulley Boys MPS with 3.4" pulley/ u-bend and resonator delete/ Custom DHP PCM/ Happy knob... more to come
