Old 11-23-2004, 01:38 PM
lorenjr lorenjr is offline
Thumbs down 95 blazer turns over but wont start
My sisters 95 chevy blazer died on her the other day and she had it towed to my house. We just did a engine swap on it and now it wont start. She said when it died the check engine light started flashing and it spitting and sputering then it died. My dad talk to a mecahnic that said to try and start it with some ether. I tried this and it still didnt fire. The only thing we had to swap for the old motor to the new one was the distributor since the guy we bought it form had broke it when pulling the motor. I checked to see if i was getting fuel which it is and i checked for spark off the coil since we broke that too and had to replace it. I never checked for spark off the distributor since it is kinda hard to see while turning the key. I will check this when the wife comes home. But has any body else ever had this problem
Old 11-23-2004, 02:41 PM
IGOTTABLAZER2 IGOTTABLAZER2 is offline
Thumbs up
Spark plug are bad or loose, or they were not set correctly! If the check engine, then putt-putt, it's definitely the spark plugs!
Old 11-23-2004, 09:18 PM
Fireplug Fireplug is offline
Re: 95 blazer turns over but wont start
If you spray carb clearner in the throttle body and it will not start then you have a spark problem
Dist , cap, coils, loose wires , grounds??
Old 11-24-2004, 06:34 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Could also be a bad crank sensor as well... Since the SES was lit, it most likely stored a code, they should be able to pull the code.
Old 11-24-2004, 11:07 AM
i have checked for spark and it does have spark
Old 11-24-2004, 12:24 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Check your CPI injector and nut kit.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-24-2004, 12:39 PM
The blazer will be towed back to the guy we got the moter from. If it is anything on the new moter it will be covered by the warranty and if I work on it it will be voided. Or thats what he told me last night. But thanx for your guys' help anyway
