| View Poll Results: Do your wipers work? | |||
| Wipers are fine |
18 | 51.43% |
| Wipers are JUNK! |
17 | 48.57% |
| Voters: 35. You may not vote on this poll | |||
Wipers
Has anyone had there wipers park in the upright position? It did it once when we bought it and the dealership fixed this but now its acting up again... Anyone have a easy fix for this? I haven't dug around under the hood yet to check it out if perhaps its a mechanical thing. If its a electrical thing then any ideas would be great!
Thanks |
Well they wont park at all now. As I understand from a inside source these wipers are pretty much JUNK! But... Not common enough for a recall!
The wipers still work though right, just won't park? If so, I believe this is common to these vans and the fix is to replace the circuit board in the wiper motor. You should be able to buy this at autozone or someplace similiar. I'm pretty sure its an easy fix, just a couple of screws, but have not personally done this. Do a search of the forum, I remember reading about this awhile back here.
OK thanks. So theres a board on the motor that can be replaced or the whole motor?
Re: Wipers
not the board, park pawl on wiper motor crank arm not catching on stop, either pawl spring broken or pawl is sticking or stop is bent, check these
Re: Wipers
hmmm.. just for the info: GM wiper syndrome as generally known relates to totally erratic wiper operation: when you would need it , it will go, no go, whenever it wants, but generally not . I do not know if this problem is pervasive in more recent year model, but the early 90's were all plagued with it.
The problem is poor/broken solder connections in the printed circuit that is contained in the wiper motor . Need not replace the board: just redo the solder. Good description is here: http://james.jaguar.net/subtopics/WiperFix.htm His early tries with an external wire as described are just for the record. It tells about a Suburban but this is same assembly for a lot of GM cars. Removing the motor to get to the printed circuit looks more a problem than it is really. You almost do not see the motor ..but it is there and once a few bolts are removed, it slides out easily for one to see. |
Re: Wipers
like i said, wiper module (board) has nothing to do with wipers parking straight up, wiper park operation has to do with park pawl on wiper motor crank arm, 15 years in chevy dealership ive seen many of these problems. yes your right they did have problem with wiper modules but very rare on ventures, more prevelant on s10 and full size trucks
Thank You very much for all of the information everyone! I asume.. havent looked yet but that the pawl is the joint that has the spring wrapped half way around? Im pretty sure im thinking if the right car heh. Im going to check both thank you much!
P.S. The rear wiper has decided to stop working also! It started out by not wanting to move then a helpfull hand it would go now its dead.(add it too the list) On a happy note the head gasket job on the 1999 montana is holding up very well! I will never do it again though lol! |
i had the same thing. i bought my 2000 montana from a bank repo. and the day i pick it up the wipers are up in the air. the motor work just wouldnt park. so i buy this 100 dollar circuit board put it on and nothing changes. i pissed away a 100 bucks because i had that black shield off and looked on top where it rotates and theres a ( ill call it a clip ) like thing that i wiggled and they have worked perfect for over a year now. good luck
There is a GM tech bulletin on this issue. It has something to do with a park mechanism that get out of allignment, its not an expensive fix.
If the wipers are parked, it could just be the screw that holds tension on the wiper gear.
Look under the triangular dust cover inder the hood. You will see the wiper mechanism on the motor. There is a procedure to reset properly. It can be found in your handy Haynes manual. |
Re: Wipers
The cog (or accentric) on top of the wiper assembly is designed, as one person has indicated, to park when a small spring loaded lever engages the stop post on the wiper motor mounting frame, as the motor momentarily goes into reverse.
This action causes the cog assembly to go off center and bring the wipers down to the cowl in the park position. When the motor is running the cog 'retracts' and runs on center, the wipers oscillating from the cowl to 'A' pillar to lower windshield. It is a poor design because dirt will eventually 'clog the cog' and the wipers will stop parking AGAIN! I took the cog completely apart, cleaned it with brake cleaner, lubricated it with axle grease and motor oil and put it back together. So far it has worked without failure (touch wood, - rapping on my forehead at this very moment!) It's a Saturday afternoon project that takes about an hour. A graphite lubricant might work better as it will not allow dirt to stick. But, being a backyard mechanic, you use what you have on hand! Be careful not to break the one-way star clip that holds the assembly together. If you do, NAPA, AutoZone, PartSource or an aftermarket shop that has odds and ends can help with a replacement clip. Last edited by 1999montana; 03-25-2005 at 06:09 PM. |
Thanks for the info! That will help alot. Im going to give it a try as soon as it gets above 30 degrees!
As for as the haynes manuel theres nothing in it about reseting the wipers. Mabey its in the chilton they have more detailed info then haynes. Atleast mine has nothing on it... Thanks eveyone Damien |
Re: Wipers
My 97 TranSport did the same thing. I cleaned all the old dried grease from the drive mechanism, cleaned the whole thing really well then regreased with light weight multi grease. Been great for two years now. (202,000 kms total now).
Steve |
I took it apart and cleaned it what a mess! I di learn one important thing that was never mentioned...
I think it would have taken alot less time if I had marked the position of everything prior to disassembly! Whoops Now im moving on to the rear wiper motor. Atleast that one is clean and really easy to change! 102000 miles so far! Many Brakes, Head gasket job done need struts rear shocks now!! Woo Hoo! |
