Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-23-2004, 10:03 AM
twomoon twomoon is offline
Iac
I think my IAC needs cleaning. Can anyone give me pointers on how to do this? I'm a chick...not that it matters...I can do this. I just need somewhat specific instructions as to where to find the IAC and what steps to take. I'd really like to skip the trip to the mechanic if possible. Thanks in advance.
Old 11-23-2004, 10:45 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Iac
what's IAC?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-23-2004, 11:16 AM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
IAC= Idle Air Controller.
What year, engine size & model do you have?
On my Rodeo, I removed and cleaned the IAC, it was easy to do. The only special tool I needed was a Torx screwdriver.
The cleaning made no difference at all.
When I had the dealer perform an engine analysis, they said my IAC was "slow to react" and installed a new one. The part cost me $72.37.
It made my engine run a little better, not much.
Strange, but replacing all of the accessory drive belts made a bigger difference in the way my engine runs than replacing the IAC.
Go figure...
Dale
Old 11-23-2004, 07:24 PM
rodeo02 rodeo02 is offline
twomoon- I'm not 100% on this, but I dont think the 1998+ 3.2 has an idle air control system. Pretty sure the *throttle by wire* system takes it's place. If it has an IAC, it will be mounted right around the throttle plate. You probably just need a good intake, throttle plate, EGR & possibly MAF cleaning. A few minutes & a can of spray intake cleaner is all it takes.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-24-2004, 08:18 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Iac
fly by wire started in 00 theree is in fact an IAC valve it is loocated on the throttle body it I belive is held in place by two phillips head screws just remove the screws pull it out clean and reinstall
why do you think you have IAC problems
