Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 11-23-2004, 09:40 AM
tclare1111 tclare1111 is offline
Angry Problems with 1999 Expedition
I have begun having some strange issued with my 1999 Expedition. Some days it is just fine. Other days I can hardly keep it running when I start it . The needles will go all the way over and it will rev up and then just idle down and die. I have to keep my foot on the gas for a few minutes and then it will eventually run, sometimes. Sometimes I will come to a stop sign or put on the brakes and it will die! Also, every now and then the odometer just goes out and them comes back on in a few minutes - HELP!
Old 11-24-2004, 02:18 AM
gr8tylor gr8tylor is offline
I'm no expert but with my experience it sounds like a fuel flow problem, try simple things like cleaning out the throttle body and replacing the fuel filter or PCV valve. Hope this helps
Old 11-24-2004, 03:00 AM
FireTruck FireTruck is offline
Re: Problems with 1999 Expedition
I had teh same problem...what i did was while holding the gas pedal so it wouldn't die i pop open the hood and the rpm went back 2 normal.......happened 2 days ago and so far is running gr8...worked 4 me
Old 12-03-2004, 02:49 PM
joe_charles joe_charles is offline
I had the exact problem......
turned out to be my idle speed control valvue.
You can read this thread... others have had this same problem
http://www.automotiveforums.com/vbul...d.php?t=289320
Old 01-14-2005, 12:06 PM
jdsmith75202 jdsmith75202 is offline
Send a message via Yahoo to jdsmith75202
Had the same problem as well. Although it wasn't the Idle Speed Control Vavle. It was the Idle Air Control Vavle.
Please see my reply at http://www.automotivehelper.com/topic344975.htm
Old 01-16-2005, 04:52 AM
yotermanic yotermanic is offline
Not to nitpick, but I can't help it an idle speed valve and idle air control valve are the same thing.
Old 10-19-2006, 10:49 PM
Gevans17 Gevans17 is offline
New IACV fixed mine. would not idle unless foot was on accelerator ....seems wat too common on the Expy
