Old 11-23-2004, 06:31 AM
Fractured1 Fractured1 is offline
Testing Rear Wiper..
I plan on going to a salvage yard later today to get a rear wiper motor...The vehicle I am removing it from has most of the front wiring removed or destroyed...I want to remove the wiper motor and with a battery that I will take with me, test the motor...does anyone know the correct wires for me to tap onto to check this out..I believe (from memory which is getting bad) there is a blue, orange, white or gray, and black...
BLUE---I think is for the washer circiut
BLACK--Ground
The GRAY or WHITE come the the safety switch to make sure the glass is closed..
ORANGE...I'm not sure of..
Thanks in advance...
Old 11-23-2004, 07:53 AM
crashflyer crashflyer is offline
Re: Testing Rear Wiper..
How much are you really saving getting a used motor? Remaned ones are about 40.00
Old 11-23-2004, 07:57 AM
I'm basicly getting a package deal...front bearing (4 wheel drive) some int components, back glass, and centers for my factory mags..for 80$$ wiper thrown in but he said if it doesn't work I can take one off another vehicle..
Old 11-23-2004, 10:01 AM
Oh okay. I would just take it and plug it in to your truck and test it.
Old 11-23-2004, 02:46 PM
IGOTTABLAZER2 IGOTTABLAZER2 is offline
No one knows off hand unless they're super good! What you do is place one on the positive, and touch each on the ground. Usually grounds are black or brown though!
Also, yeah, a rear wiper from the Junkyard is a fine idea, because rear wipers aren't used as much as front! I barely use mine!
