Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-23-2004, 01:42 AM
Z32TT_maniac Z32TT_maniac is offline
turbo charge and super charge
they are not quite similar are they? and which one spool harder..one of my friend told me the super charge spool much harder..he said a V8 car with a super charge is just like a V12 car..wat the phuck!!!??? dats bullshiet
Old 11-23-2004, 01:50 AM
Hodo Hodo is offline
Re: turbo charge and super charge
Super charger works on belt drivin power, it takes power to make power with a super charger, plus side to them are they are imediate power. Turbo Charger, uses exhaust gasses to turn the turbine to make power, takes NO power to make power with a turbo, down side is some of the larger older aplications have lag, and take time to reach full potential. As for the 300ZX you are quite safe with a twin turbo set up, it works great to moderately small turbos set up to make great boost at decent RPMs. Its all a mater of preferance really.
Niether will pull harder than the other, Turbos have a greater potential to make more power than a Supercharger but they cant make the power at the lower RPMs as there is not enough exhaust gas flow to spool them fast enough.
Old 11-23-2004, 02:16 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
lol dude... wow...
http://auto.howstuffworks.com/
http://www.automotiveforums.com/vbul...d.php?t=283043
http://www.automotiveforums.com/vbul...d.php?t=201348
it's amazing what you can learn from reading...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 11-23-2004, 02:19 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
if you have a 300zxTT, superchargers should be the last thing on your mind.
ZedEx Crew Member #4
Old 11-23-2004, 02:21 AM
I am surprised he doesnt know the difference..... Mad Max used a supercharger........... loads o' fun on Big Blocks..... no good on little engines, less than 450Ci.
Old 11-23-2004, 02:25 AM
Z Cars Fanatic
yeah...unless you have both. i posted a link to a car that nissan produced in japan. it was a little hatchback that was 900cc's if memory serves me right. it was supercharged and turbocharged. pulled 0-60 times in a little over 7 seconds i believe. NOT BAD for a bike motor in a 2500lbs car.
just another reason why nissan rule's all!!!
EDIT: here we go i found it again. http://www.autospeed.com/cms/A_2216/article.html
Old 11-23-2004, 06:45 AM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
this topic has been done to death. we have had a huge debate on this already. the only thing that came out of it was that it all depends on what you like, turbochargers and superchargers have their own highs and lows, and it all equals out in the end.
-Jared
ZedEx Crew Member #2
Old 11-23-2004, 01:19 PM
DeleriousZ's Avatar
i want that super-turbo... i wonder if they're old enough to import yet
Old 11-23-2004, 03:10 PM
I want turbine power....... Pratt& Whitney power..... JET POWER!!!! The ultimate turbo. :P
Old 11-23-2004, 05:00 PM
speaking of pratt & whitney, when i walked into work the other day, there was two brand spanking new pratt & whitney jet engines sitting on the floor. i would like to know what people pay for shipping for one of those.
-Jared
Old 11-23-2004, 05:19 PM
neogenesis neogenesis is offline
If you're serious about more power from turbos and fear the lag, you could always use apply nitrous and have it shut down when the turbos do reach it's high potential.
Old 11-23-2004, 05:21 PM
DeleriousZ's Avatar
good point neo.. once you hook that up it would be hard not to soil yourself every time you hit wot
Old 11-23-2004, 09:48 PM
Zgringo Zgringo is offline
Here we go again.
Hodo, sorry good buddy but both take take power to run, granted the turbo uses less, and low RPM's with turbo's has nothing to do with lack of power.
All of Pratt & Whitney piston engines had superchargers. There jet engines have axiel flow compressors.
K3 I'm ashamed of you. What do you think I run on my cars? JK, bud.
DeleriousZ I'm proud of you. Point'em in the right direction.
Freak your right, it's been beat to death and it appears a few haven't learned yet. As for those jet engines, little ones cost from $40,000 up, and the big mother's can cost in the millions.
OK school's open.
First of all a engine makes it's power with compression ratio. No compression no power, like burning gas on open ground, nothing but fire. The higher the compression ratio the more power the engine makes. The compression ratio is the multiplication factor of pressure on top of the piston, which makes power. I'm going to give 3 examples, only examples.
Engine #1 14.5:1 compression ratio
Engine #2 8:1 compression ratio with 12lbs boost
Engine #3 10:1 compression ratio with 7lbs boost
Which one of these engines well make the most power? And what's the difference in compression ratio of these engines?
http://www.goodvibesracing.com/Compression%20Ratio.htm
There is no difference except for the turbo engine, as follows.
Engines with low compression ratio's have very low bottom and mid range power, and no top end power. Thats where the turbo comes in.
Car mfg. engineers who build turbo cars find it easer to build production car engines that are turbo'ed easer to control with 8:1 pistons than with higher compression pistons. So the so called turbo lag is bull shit. The turbo just isn't making enough boost to raise the compression ratio enough to make power yet, but when it does make enough boost, bang, lots of power. That's why it's so easy to make so much power with our cars. The engineer's have detuned our car's so far, almost anything well improve it's performance.
Now a supercharger on the other hand is a positive displacement compressor and makes boost when ever the engine is running, so it's boosting the compression right off the start.
Now we can mask the so called turbo lag by installing smaller turbo's and lose top end, or inject nitrous in the low to mid range to over come the lack of compression ratio, or we can start with a higher compression ratio and a lower boost and have the same compression ratio the entire RPM range without the so called turbo lag.
With proper engine management (ECU) and good fuel it isnt a problem.
Because years ago fuel was the shits and so only engines with low compression pistons could handle turbo's (superchargers). Now with our technology it isn't true anymore.
Old 11-24-2004, 01:17 AM
Z Cars Fanatic
awww....come on. what did i say now??? all i said was that if you TT and you dont plan on doing no ridiculous 1/4 mle times or anything. superchargers should be the last thing on your mind.
Old 11-24-2004, 01:49 AM
Re: Re: turbo charge and super charge
OK, you get all you atta boys back, I'm sorry
By the way. Did I explain it clear enough this time?
