Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 11-23-2004, 01:09 AM
FireTruck FireTruck is offline
Unhappy 2000 expedition 5.6L Eddie Bauer
Hi every1.......2 days ago when i got in my suv i tried 2 start it like i do every night but engine wouldn't start with out hiting the gas pedal. B4 i was able to start it with out the gas pedal.Also RPM are 500 rpm/m and they used 2 be around 1000 rpm/m 1500 rpm/m when first started. No snow yet so weather is not very cold. When i let the gas pedal go it shuts down or when i hit the brake and switch from P to D .....like i said the only diference i noticed is the rpm......any ideas?? ty in advance
Old 11-24-2004, 03:15 AM
Re: Low RPM
I think i fixed it...kind of stupid if it did....i just holded the gas pedal 2 a 1000 rpm and pop open the hood as soon as i did that rpm stayed a 1000 rpm w/o holding the gas pedal and then went to 700 or 800 rpm....it's been 2 days so far and stil works fine...wil let u know if it happens again...knoking on wood
Old 12-01-2004, 12:28 PM
jason_marshall1 jason_marshall1 is offline
I just fixed a similar symptom yesterday. My issue started when I had to open the accelerator before the engine would start in cold weather. Once the engine warmed up a bit, it ran fine. This was the case until Monday when it would not start when warm. After chasing vacuum lines and ensuring no pvc/ egr leaks, I tested the Idle Air Control Valve. It was stuck closed. After a little carb cleaner and prying it open, the engine began to start just fine. After ensuring this was the root cause, I replaced it for $54. Replacing the valve was not as difficult as I expected; less than ten minutes in and out.
hth
Old 12-02-2004, 12:32 AM
Re: Low RPM
Ty for your info Jason......mine still works fine so far...but in case i need to change it...where should i look for that idle air control valve?? i mean where is located
Old 12-02-2004, 04:52 PM
I have a 2000 5.4. Mine was just behind the throttle body. It has two small bolts (8mm) that point to the left front fender. It's just above the pcv hose meets the intake.
Old 12-03-2004, 12:38 AM
Re: Low RPM
cool...ty
Old 12-03-2004, 02:44 PM
joe_charles joe_charles is offline
I also had a simular problem. appeared to fix it's self for a while, then got worse. It turned out to be the idle speed control valvue.
It's a little harder to find and replace. It's real close to the fire wall and the bolts are on the back side (at least on my 1999) so I decided not to do it my self. I took it to GoodYear. They charged me $67 for the part and $53 for labor..... but I had them run the Diag which cost additional $89. The diag confirmed that was the problem.
