plugging air injection tube
during my trans install, the air checkvalve on the tube that connects to the back of the heads broke off, leaving the large nut-lookign thing open, resulting in a large exhaust leak. what is the best way to fix this without trying to plug the heads?
-Andy '89 Mustang 5.0 - How fast? i'll know this weekend. '86 Mustang LX - Shortblock is built, now for the rest of it. "Put the subject before the verb, hmm? Fail this class, you will." -Yoda teaches english class. |
Re: plugging air injection tube
If possible, you may want try to glue the valve back together using J.B. Welds epoxy. |
You can plug the back of the heads by flipping the fittings over....If it's an offroad or aftermarket cat setup anyway.....
Then you just weld the fitting on the H-pipe up and eliminate all the crap from that side of the engine bay...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons..... http://www.cardomain.com/id/mccobra94 1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster. Freedom Isn't Free. |
J.B. weld had occurred to me, flipping the fittings over hadn't... that's a good idea... is it doable with the motor in the car? do i just cut the pipes off? and, will orange RTV work?
I slapped mine on dry. No problems. Was done with the motor in the car. Hardest part is cutting the pipe that runs from one head to the other. Used a dremel and cutoff wheel.
As for the rest of it, I crimped the end near the H pipe and welded a bead across it, then removed ALL the rest of the piping (and the smog pump) went in the garbage.
Re: Re: plugging air injection tube
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt. |
Nope, used up all the duct tape on the damn dodge.
