Old 11-22-2004, 11:04 PM
sheng sheng is offline
Send a message via AIM to sheng Send a message via Yahoo to sheng
speed sensor???
can u tell me where the speed sensor is located????? some people told me you can gain a few more RPM by removing this sensor>>>>>>
Old 11-22-2004, 11:06 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: speed sensor???
the bigger sensor under your distributor,
located on the head!
I'n not so shore about some hp!
In the process of B00stin my D
Old 11-22-2004, 11:15 PM
Re: speed sensor???
is not exactly you gain HP , but RPM maybe you do
Old 11-22-2004, 11:17 PM
Re: Re: speed sensor???
well,when you disconnect it,
it does raise the idel
& it will throw a code in your ecu
if your going to do it,
just disconnect it,
dont pull the sensor out itself,
coolant pours
Old 11-22-2004, 11:26 PM
Re: speed sensor???
wich time u think is aceptable for this engine, swaped out on a 4th gen, run on 1/4 mile??
Old 11-22-2004, 11:27 PM
I dont know what kind of engine you have....
let me know
& I'll take an educated guess.
Old 11-22-2004, 11:31 PM
Re: speed sensor???
B16a vtec twin cam
Old 11-22-2004, 11:35 PM
Originally Posted by sheng
B16a vtec twin cam
wow,well,
thats probably not where your speed sensor is,
maybe someone on the AF has one installed & knows or somthin,
take it for a run down the track once in a while,
you have any pictures?(that would be best)
I would say stock vtec b16,
my friend had a b18 twin cam stock,aem,3" exhaust all the way back,
in a honda acura & he ran a 16.2
gl
Old 11-22-2004, 11:57 PM
Re: speed sensor???
well y used to have and integra 90, whith a B18a non vtec an i ran 15.8, just whith little tricks i did, all stock engine
Old 11-23-2004, 05:20 PM
shaddr3 shaddr3 is offline
Send a message via AIM to shaddr3
Re: speed sensor???
I ran 13.7 with my B16 rex :-p
89 CRX Si
B16 | BW Body kit | 17" 8 Spoke | Airbagged
Old 11-23-2004, 06:02 PM
!M!}['s Avatar
!M!}[ !M!}[ is offline
Re: speed sensor???
do u mean vehicle speed sensor if so its on the tranny and i dont think u will gain anything but a ecu code, no vtec and no speedometer
Old 11-23-2004, 06:39 PM
91civicDXdude's Avatar
Re: speed sensor???
actually, the vehicle speed sensor is located on the back side of the instrument cluster. on cable speedo cars, the thing in the tranny is simply a gear to drive the speedo cable, which in turn drives the VSS on the back of the cluster :P
Electric VSS simply bypasses the cable and the gear that runs off the differential spins some sort of sensor directly, in which it then puts off a pulsed signal to the ECU... just like the cable one.
Old 11-23-2004, 08:09 PM
!M!}['s Avatar
Re: speed sensor???
well he still will not gain anything from removeing it and that is what it seems like hes asking
