Old 11-22-2004, 10:04 PM
marco100 marco100 is offline
92 f150
I have a 92 f-150, 302, auto, king-cab long bed with dual fuel tanks. And it has a problem, when you go out and start it and let it idle it will flood and die. After it has warmed up then you try and start it it will not start unless you put the gas pedal to the floor, after it starts it runs like crap, the idle will surge. Anyone know whats wrong?
Old 11-23-2004, 05:27 PM
mustangmike351c mustangmike351c is offline
92f150
is your check engine light on? if not check your air filter and vacuum line going to the map sensor.
Old 11-23-2004, 09:38 PM
Re: 92 f150
the check engine light isnt on but who knows it may be unhooked. the air filter was all black and gumming looking, put distrubor cap and rotor on it, still does the same thing, putting plugs in it tomorrow. and will check that line to
Old 11-23-2004, 09:45 PM
Re: 92 f150
where is the map sensor?
Old 11-24-2004, 05:40 PM
map sensor is on the pass. side beside the heater box. Have you tried running it with the hose off the airfilter?
Old 11-24-2004, 10:04 PM
Re: 92 f150
going to put the plugs in tomorrow, and check the map sensor. no we havnt tried running it with the hose off the airfilter, because now it will not start.
Old 11-25-2004, 11:01 AM
Re: 92 f150
ok got it running, but now its running rich. anyone know whats could be wrong?
Old 02-13-2005, 01:16 AM
jcougar88 jcougar88 is offline
Re: 92 f150
sounds like the tps(throttle positioning sensor)is going bad. sometimes this is an intermitent problem. runs about 35 bucks. good luck and hope this helps
Old 02-14-2005, 03:42 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 92 f150
Idle Air Control. Clean or replace it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
