Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-22-2004, 09:10 PM
98 dodgeRAMmike 98 dodgeRAMmike is offline
Does anyone know if there are aftermarket replacements for the forward suspension arm
I have replaced my tires with Toyo AT 285/75R16's and when I turn the steering all the way to the left, the inside of the tire on the drivers side rubbs the upper forward suspension arm. I have already put spacers on the fronts and I still ahve the problem. Is there a company that makes replacement suspension arms ?
Old 11-23-2004, 08:46 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Does anyone know if there are aftermarket replacements for the forward suspension arm
most suspension lift manufacturers have replacement arms, however I don't think new arms will solve the rubbing problem. there are several people on another board that have rubbing isues even with replacement arms, because the replacements arms(unless you go to a long arm setup) are in the same location as the stock ones. I think the only way to eliminate the rubbing would be to either use wheel spacers (not highly recomended) or go switch to a wheel with less back spacing to move the tire out and away from the arms.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
