| Off-Topic Talk about anything other than cars. |
Can you help my friend out?
Please help my friend... its been 7 1/2 months now and still not running. We are at the point where we have no clue and replaced everything. By the way this is my shop... actually My dads but Mine. Spare motors anyone want to buy some part off? or the whole motor.. not running tho. good for a project motor. =) 4g16 95-99 My project 420A My dads toolbox
![]() 1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05 Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18 |
Re: Can you help my friend out?
I like the oldie in the 1st pic. Ill take that.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Re: Can you help my friend out?
haha thats my dads 1970 Buick Skylark with a 455 Big Block... shit is fast but.. too much gas =\
well we need to know what the car is doing first and what you've done to it to even help you out the slightest little bit.
well I can crank it and it wont start. i have new crank & cam sensors on.. timing right.. new oil pump... relays.... coils... so im stuck. =\
do you have spark? fuel? if you have both of those then its gotta be a timing problem usually. unless your intake or exhaust is blocked completly
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
No spark to the heads.... I remember when i scanned it it said something like weak coil. or something. But yeah... no spark to the head.
Could your ecu be bad?
Blowing motors since 2005. ![]() 1995 Eclipse GS 5 Speed(White) 1995 Eclipse GSX 5 Speed(Silver) Need a file hosted? IM me. For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.Quote:
did you try replacing the power/coil pack on it? wires? plugs? don't worry about all that other stuff until you get spark. stick with the ignition system and you should be good.
TalonESI: a bad ecu can also cause a no spark condition. if you had read the whole thread you would see that he has "i have new crank & cam sensors on.. timing right.. new oil pump... relays.... coils... so im stuck. =\"
that is what my dad is guessing. we went trough 3 differ ECUs and no spark. MY dad wants to borrow someones ECu to see if that will work, but he dont want to spend $700 for a new ECu yet because hes scared it might not be the ecu. =\
just steal one from the junk yard........lol
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
