Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-22-2004, 07:43 PM
The Ride The Ride is offline
Question electiric windows
My driver side window has to be helped to lower or raise. I am considering taking off the door panel to see if something is out of line and basicly how the window is supose to work. Any ideas.
87 Z
Old 11-22-2004, 08:57 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: electiric windows
if it is moving, but needs helped, than it is most likely the motor.
-Jared
ZedEx Crew Member #2
Old 11-22-2004, 09:02 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
my metal folding pieces (i cant think of a technical name or think of somethign else to call it) got bent somehow in my z32 causing it to make a real bad clicking sounds when i would roll it down and up. this eventually led to having to be helped up and then eventually stop moving period because it got jammed. this could be your problem but i think my metal folding pieces got bent from someone trying to break in my car with a jimmy or something. so im probably with freak here, in saying that your motor is probably starting to go out.
i dont know about on the z31's but on the z32's it is a huge pain in the ass to change that over. on the z32's they left 2 little holes to dig your hands through.
ZedEx Crew Member #4
Old 11-26-2004, 02:37 AM
ForceFed300zx ForceFed300zx is offline
I have the same problem!
I have an 86 with the same problem. I don't think it is the motor because atleast in mine, I can hear the motor working. It will barely move down and wont move up at all but I think the motor is fine. I am taking apart mine. I will let you know what mine is and hopefully I can help you.
Old 11-26-2004, 02:47 AM
Hodo Hodo is offline
if the motor is going bad you will still hear the motor tring to work. Do a voltage draw test on it and see what kind of power its sucking to move. Check the manual for its specs. Odds are its the Motor and the guides.
