Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 11-22-2004, 07:36 PM
fi1000 fi1000 is offline
Question toyota locked steering wheel-key won't turn
Hi,
I am a new member - and hope this is how your site works. I have a question I know one of you will be able to answer. I have a 1990 toyota celica. The parking attendant somehow locked the steering wheel and the key will no longer turn in the lock. I tried everything i could think of: turning the wheel whilst turning the key, putting car in all positions other than park and then turning the wheel and key, changing the key, etc....The steering wheel remains locked and will not unlock. Do any of you know the trick to get it unlocked? Apparently this happens quite a bit in toyotas.
Thank you,
fi1000
Old 11-23-2004, 02:35 AM
nialusa nialusa is offline
Send a message via ICQ to nialusa Send a message via AIM to nialusa Send a message via MSN to nialusa Send a message via Yahoo to nialusa
Re: toyota locked steering wheel-key won't turn
This has happaned to me before, although not on a Celica,squirt some WD40 into the keyhole and get a friend to rock the steering wheel left,right,left.right etc while you try and turn the key. This `should` work.
Old 11-23-2004, 07:13 AM
NyneWun_Cell91's Avatar
NyneWun_Cell91 NyneWun_Cell91 is offline
Send a message via AIM to NyneWun_Cell91 Send a message via MSN to NyneWun_Cell91
yeap just crank it to the right a little and it should unlock, atleast mine does when this happens?
Old 11-23-2004, 12:11 PM
91 Celica St 91 Celica St is offline
AF - Advisor
he mighta broke the ignition swtich
Old 12-08-2004, 06:07 PM
Re: Re: toyota locked steering wheel-key won't turn
Hi
Thank you for the advice about the squirting WD40 into the key hole- you were exactly right- I actually ended up doing that as a desperate measure just so i could get myself home and am glad to see that was the right thing to do. Ultimately, i will need a new car or a new ignition...
THanks for your advice!
fi1000
Old 12-08-2004, 06:09 PM
AF - Advisor
yeah its ur ignition swtich...ad thing is you probably just effed it up more, haha ive had one break and my car was stuck on, if that ever happens disconnect the main plug wire from your distributor cap
Old 12-27-2004, 05:57 PM
firestarter69 firestarter69 is offline
I had to go to the junk yard pull the whole ing. sys. then install it in mine
Old 12-28-2004, 03:14 PM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
On my 3rd gen the problem would be that the key would go too far into the ignition. Don't know why, but that was what happened to me so i would have to wiggle the key in the ignition till i had pulled it out to the correct distance. Before I figured this out I almost twisted my key off, it's a bit twisted, but still works =P
RAs, the last of the RWD Celicas... http://truestreets.com/ now out of BETA
Old 12-23-2008, 09:59 AM
takermama takermama is offline
We just had similar problem on 2007 Highlander. We have a steep driveway and I parked it the other night and it was kind of snowy/icy. 2 days later tried to start and couldn't get key to go in. Jiggled steering wheel and no luck. DH though managed to get key in, but key wouldn't turn and steering wheel locked. After reading posts, we put in some WD40 into the key hole dand tapped on key/lock steering wheel, that didn't do it right away, but then I jumped on the front bumper, as someone suggested (since it was on incline) and that with the WD40 did it, thank God, or would have had to tow to Toyota the day before Xmas...
Old 06-19-2011, 05:44 PM
Newhampshireboy Newhampshireboy is offline
Cool Re: toyota locked steering wheel-key won't turn
Today, my wife's 2009 Corolla ignition locked up. I will try WD40 and hope it works because nothing else works. Toyota engineers should correct this problem as it is quite common!!
Old 12-07-2012, 09:32 AM
svilla svilla is offline
Change your key !Your old key maybe worn out.
Old 01-08-2013, 02:23 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Try to avoid responding to old posts. They car probably has been fixed by now.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
