Old 11-22-2004, 07:27 PM
ooljima ooljima is offline
Send a message via AIM to ooljima
replacing valve cover gasket....questions.
where can i get one for a good price.
anything i should know?
just tell me the info
Old 11-22-2004, 07:29 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: replacing valve cover gasket....questions.
you should be able to pick one up for around $20-30 at your local napa or automotive store. if you can, get a fel-pro. they fit way better and last a lot longer.
95 Talon TSI AWD
97 Eclipse GST
Old 11-22-2004, 07:48 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
use a torque wrench on the bolts. the valve cover cracks realy easily. i think you torque them to 20 INCH pounds but check a shop manual or vfaq.com to be sure. also make sure that the spark plug hole seals stay put maybe stick them on with gasket sealer.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
