Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 11-22-2004, 08:10 PM
bond67 bond67 is offline
Unhappy 2000 sable still has check engine light after replacing plugs,wires,etc.
2000 sable still has check engine light after replacing spark plugs,wires,DPFE Sensor, & EGR Valve. I'm out of options. I've been to the Dealer TWICE. I've been charged both times and the car still has a check engine light and runs poorly. Gas mileage has suffered horribly! Please help!!!!
Old 11-22-2004, 09:00 PM
Raindancor Raindancor is offline
Did you try O2 sensor?
Old 12-23-2004, 07:25 PM
Marathonman Marathonman is offline
Re: 2000 sable still has check engine light after replacing plugs,wires,etc.
Well Tell you what. When you figure it out please tell me. http://www.automotiveforums.com/vbul...83#post2461683
Old 12-26-2004, 11:25 AM
riproaringca's Avatar
riproaringca riproaringca is offline
Check Engine Soon light
My light has been on for two years now (52,000km since it first lit-up) I have replaced the plugs, pcv valve, fuel filter, air filter and plug wires, too. When I took my '97 Sable in for a regular transmission fluid change/service, the guy there told me that the code that came up on the computer suggested it was a 'Camshaft' issue. That was back in July '04. The really weird thing is that in Dec. '03 I had a mechanic tell me that the computer code was a Transmission Code - '17', I think it was.
My car runs fine (knock on wood) and does not suffer from the poor mileage problem. So, I wonder if in my case I'd be chasing an electrical glitch if I investigated it further. Ay eight years old, my Sable has 195,000km on it now, so I'm not going to throw a lot of $ at it. It's almost time for an Escape!
For your problem, I'd make the friendly suggestion that you make sure you don't have a caliper piston that is starting to sieze causing a brake to 'drag', since you've replaced other items - ones that I would have done first, too! You didn't mention replacing the fuel filter - that might help mileage as well if your's is aging and dirty.
Old 01-08-2005, 06:25 PM
riproaringca if you last comment was to me. I just had the brakes redone becouse it was just time for it. So I know they are fine.
Old 01-18-2005, 10:48 AM
Banjoman10 Banjoman10 is offline
Sorry guys, I just don't get these replies. The first logical question would be, was the OBD read? If it was, what was the code number, and subsequently what kind of malfunction did that indicate? Rule 1(!): If the engine light is on, (continuous, not blinking) you've got an OBD message (malfunction) to be read. You need an OBD reader tool to read it. It can have more than one message at the same time. For instance after the initial code of "Insufficient EGR flow" you'll be likely to get also (a different code number) "Both banks too lean", the first malfunction will create the second. Anyway, it can be a multitude of things, and you can do tune-ups til doomsday, and it will not likely to be fixed, unless you just get lucky.
Old 01-18-2005, 11:30 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
If you post the obd codes maybe we could help.
Old 02-02-2005, 11:00 AM
ugothim ugothim is offline
Send a message via Yahoo to ugothim
try replacing the fuel cap !
