Old 11-22-2004, 06:34 PM
$hott-boi$ $hott-boi$ is offline
resonnator bottle removal
my friend was telling me about removing the resonator bottle, but unfortunatly he's in college and cant help me out with it first hand, so can anyone help me with some instructions, he said its pretty easy....
Old 11-22-2004, 06:47 PM
Gateway's Avatar
Gateway Gateway is offline
Re: resonnator bottle removal
http://www.3si.org/pages/resonator.html
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 11-22-2004, 06:56 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Its real easy, hardest part is finding something to block it up with.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-22-2004, 08:46 PM
Im2Fast4U Im2Fast4U is offline
You could just get a hard intake pipe. It eliminates the resonator easily and gives you some nice bling under the hood . 3SX and Dynamic among others have them.
1993 Dodge Stealth
yes, it has mods....
R.I.P. DAD NOVEMBER 3, 1952-NOVEMBER 25, 2002
I LOVE YOU
Old 11-22-2004, 09:04 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ya if you're goin for bling, then the intake hard pipe is the way to go. however, you won't gain any hp.
BUT, if you just want to remove the resonator to make your intake sound louder, then simply remove it and i've heard that the top from a peanut butter jar will fit nicely. heck, just measure the diameter of the opening, then go to the grocery store and shop for similarly diametric food jar tops.
happy shopping!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-22-2004, 09:34 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: resonnator bottle removal
Peanut butter jar lid is way too big. You need something like a pill bottle lid. I used the lid off a bottle of Pepto Bismol.
Old 11-22-2004, 11:08 PM
Kev3000GT Kev3000GT is offline
Milk jug bottle cap for me!
Old 11-22-2004, 11:19 PM
Hotshot8792 Hotshot8792 is offline
just make sure whatever you use that you clamp it down so that it doesnt get sucked into the throttle body
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 11-22-2004, 11:59 PM
sLADe781 sLADe781 is offline
So removing the resonator is only for sound right? What if when you replace it with an intake pipe like the one from 3sx. What happens to the resonator then? Do you still need something like the jar to hold it in place or whatever? Also, since the jar is made of plastic, wouldn't it melt? What's the point of the resonator to begin with anyways?
Old 11-23-2004, 11:09 PM
3000Star 3000Star is offline
Send a message via AIM to 3000Star Send a message via Yahoo to 3000Star
well its 12am and i was bored and i desided to bypass my bottle and it only took me five minutes a screwdriver and a tylonel cap..wow that was easy
Old 11-24-2004, 04:39 PM
Thourun's Avatar
Its like a silencer or muffler for your intake. Take it iff and theres just a hole in the tube, replace hte tube with an aftermarket one and there is no more hole.
1995 3000GT VR-4
Old 11-25-2004, 11:19 AM
Linebckr49's Avatar
that's exactly one of the problems that's arisen here in this thread. i think most people agree with me when i say that to replace the intake tube with an aftermarket one is just pure bling. our intake flow characteristics are just about efficient as they can be. that's why this thread is titled "Resonator Bottle Removal," that is what we're trying to do, and for the sound gained, your only expense is a bottle top, instead of a $50+ new intake tube that will net you 0 hp.
93 3000GT base
Old 11-26-2004, 09:28 AM
Pulowski22_7 Pulowski22_7 is offline
i took mine off yesterday and took the car out to see if i could hear the difference. there really isnt a difference but at 6k rpms there is a high pitch squeel and then it stops when i keep it gunned. what is this sound? does it mean my replacement for the hole the bottle leaves is not tight enough or strong enough? i used a cap off of a shoe cleaner spray. just like a spray paint bottle cap. should i use something stronger? im thinkin i should just put the res bottle back on
Old 11-26-2004, 12:28 PM
Igovert500's Avatar
blue + red light magnet
2 easy ways to check if it is leaking air.
1 soapy water, 2 a thin strip of paper, whichever you go with, put the soapy water around the seam, or move the slip of paper around the edges...as you are doing this, have a friend give it some gas. IF you get bubbles or if hte paper starts waving from escaping air..u found a leak...if not, hten I'd think your fine.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
