Old 11-22-2004, 05:58 PM
hypnotizemindz hypnotizemindz is offline
True Duals on a Silverado ???
how can you put true duals on a silverado ??
there's the exhaust sensor in the cat convertor....
how do you get around that ?... and does it damage the motor in any way ?
and is it a big increase from just changing the muffler and tips ?
i'm new to the board, please let me know
Old 11-22-2004, 07:29 PM
busta's Avatar
busta busta is offline
yo
welcome, umm i dont think there really is anything called TRUE DUALS iam sure that they'll connect via x-pipe or cross pipe to even out the presure between the 2 for better performace, i could be wrong? be sure to check out the banks power pk look's like a winner?
-i love paintball
-i love datsun z cars
-oh i love my HARLEY!
-class A mechanic
-heavy eqipment mechanic
-equipment operator
-mig,tig,arc welder
-lemon silverado owner
-pistonslap.com
Old 11-22-2004, 07:35 PM
busta's Avatar
sorry
damn sorry about hte double post's guys umm i have seen FAKE o2 sensors that send a signal to the ecm to trick it into thinking they are installed i guess it always sends a return signal of .5v
-i love paintball
-class A mechanic
-equipment operator
-mig,tig,arc welder
-pistonslap.com
Old 11-22-2004, 07:39 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: True Duals on a Silverado ???
Well first off there is no sensor IN the cat..... there is one before AND after on EACH side......4 o2 sensors in all. A true dual system is what i consider i have on mine..... Each side is seperate from the other....... one cat , one muffler on each side. I had my system installed by getting the muffler shop to cut the factory exhaust off just before the "Y" pipe where it is still 2 pipes and had them continue dual the rest of the way. They also installed a balancing tube or blending tube as it is sometimes called because I had an issue of power loss initially after system was installed and they thought that the tube might help, which it did not. Anyways , that is what i call a true dual system, each side is independent from the other, not just a single in , dual out muffler. Oh and by the way I did get the power back eventually, when the computer was able to make the necessary adjustments on it's own (disconnecting the battery did not help)
Old 11-22-2004, 07:45 PM
kenny-1907's Avatar
Was in the middle of typing my post when busta entered his. I was gonna add that it kinda depends on how a person would define "true duals". I had duals on my 88 full size jimmy, no crossover pipe, the same with my 96 sierra with the 5.7, man that thing went. 255/85/16's on it and when doing 35-40 kmh if i floored it , it would break them loose when it kicked down and then chirp them into second.
Old 11-22-2004, 08:12 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
I'm running a dual setup, but opted to install an xpipe before the two headers to even out the exhaust flow. My long tubes had bungs in them for the front 02 sensors, and I had the rear 02 sensors removed from the computer. I also deleted the cats.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 11-22-2004, 09:23 PM
ryanszpara's Avatar
ryanszpara ryanszpara is offline
Send a message via AIM to ryanszpara
so im going to get a "dual" exhaust put on my 02 silverado next week........I have an original 40 series flowmaster (single in dual out) that im having them put on instead of the crappy v-force muffler that they offer....is this even going to be worth it?? I know its not "true Duals" but its all i can afford....is it worth it??
Thanks
2002 Chevy Silverado
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FM 40 Series-dual turn downs
FUTURE PLANS:
3 inch lift
285/75 r16 BFG A/T s
Wheels? (american racing)
Old 11-23-2004, 12:02 PM
Thanks
I think you'll be happy with the sound and performance. Go for it.
Old 11-23-2004, 02:51 PM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Yea, mine is the same way...single in, dual out. I like it. I wasent really down on spending all that money to put in true duals, but i will say, my system sounds just as good as most trucks who do have "true" duals. My one friend crawled under my truck a few months ago...all I heard was.."You only have one muffler? damn!" I guess he was expecting something more impressive. I also got a nice bit od added hp. I have also cherped them while already doinr 20-30 mph. I was impressed. Im sure its not good for the tranny, but its fun.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 11-23-2004, 05:26 PM
duals
yeah, i was gonna copy the system on sshotrods.com.. with the dean lapole headers, xpipe, 40 series, and maybe some high flow cats... but now people are saying the single in, dual out is like the same performance....
i got a 4.8... incase i get indicators for the o2 sensors.... i cant find any simulators for the 4.8.. only the 5.3 and bigger...maybe they'll interchange ?
im not used to modding newer vehicles... i'm used to the old school stuff, with carbs, not tbi =]
please let me know the best option for sound & performance..
how about a tuner ? should i go with a programmer ? or send off my PCU
Old 11-23-2004, 09:46 PM
Re: duals
This is the best way I can explain my feelings on true dual setups. There is no doubt these trucks run better off of backpressure. A true dual setup will knock out some low end grunt but make it up in the upper power band. On a slightly modified/stock truck, I would not go with a true dual setup, because the low end loss would be extremely noticeable and probably wouldn't be made up enough in the higher range to compensate for the low end loss. An xpipe definately helps to smooth out exhaust flow. I went with the true dual setup because my setup is for mid/high range power band. My cam powerband is 1600-6600rpms and I have a 3000 stall converter, not to mention a 6.0L. The stall allowed me to let go of some of the bottem end, because at full throttle, my rpms never drop below 3200rpms.
So, bottom line, a single inlet dual outlet muffler with the cats will allow for enough backpressure to keep the low end grunt, so I would stick with that.
Some guys will argue that backpressure has nothing to do with anything on this truck. The best thing I can tell them is let me take you for a ride, both with my cutouts closed and cutouts open. With them open(they are right behind the headers), my truck really feels sluggish(compared to closed) until I reach the high end rpms. That is proof alone the backpressure is needed.
Old 11-24-2004, 04:31 AM
pipes
so leave the Y pipe and just change the muffler and tips ?
i was thinkin about headers also...
you recommend just change the muffler and tips ?
Old 11-24-2004, 07:03 AM
busta's Avatar
yip
ya change the muffler and tips for sure! and if you buy headers EVERYONE says go with the long tube not the shorty's!
-i love paintball
-class A mechanic
-equipment operator
-mig,tig,arc welder
-pistonslap.com
Old 11-24-2004, 05:46 PM
duals
whats wrong with the shorty's ??
Old 11-24-2004, 08:32 PM
Re: duals
They don't flow a whole lot more than the stock manifolds. You won't see near the performance with shorties that you will with mid lenght or long tubes. Check out Summitracing. They offer some Doug Thorley long tubes for our trucks at aroun $430. Not much more and in some cases less than shorties. Good luck on your decisions.
