| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
vibration in steering wheel
1991 accord 125000mi, slight vibration in steering wheel at very low speed. Steering not loose. Smooths out at normal highway speeds. ??????? Thanks or your help.
Re: vibration in steering wheel
It could be many differnt things such as:
Wheel out of balance Upper strut mounts Strut Spring Control arm bushing Tie rod Ball joint Wheel bearing Warped rotors Worn brake pads Frozen or bad brake caliper Bent wheel Steering rack Slipped belt or cupped tire CV joint worn Axle not balanced correctly Loose wheel The easiest way to check the front end is jack it up and support, not under the wheels. Grab each tire and shake it in all direction, if you fell any play then a further inspection is needed. You should be able to see & hear the part thats bad. It's hard to pinpoint your problem without having the car here. That's something you need to see & feel. |
sounds like a bad tire to me...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Do you have aftermarket wheels and tires? If so and it only occurs at a certain speed it's usually an out-of-balance wheel/tire OR bent wheel.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
now, i have the same problem over here, i have tried 2 set of rims/tires same size of rims... nobody cant find what the problem is, honda says its the type of rims i have (17")... i cant take for an answer... ive been to about 10 different shops for balance and nobody see anything wrong with my car. do you guys know any good shop here in south florida? i have to find out what the problem is.
![]() thanks
Acura RSX 2005 5-Speed DC Race Header SS Greddy EVO2 SS Injen CAI AEM Tru-Pulley Hondata K-Pro |
If your wheel is bent the balancer might not see it and just fix it with weights, but it will still be out of round. If you take off your wheel and run your finger along the rim of the inside and outside of the wheel you might be able to feel it.
Re: Re: vibration in steering wheel
1991 Honda Accord steering wheel vibration
My problem was solved when I replaced the left front tire. Lessson: check the simple things first. Thanks for the help. David
Re: Re: Re: vibration in steering wheel
Re: Re: Re: Re: vibration in steering wheel
many aftermarket wheels don't accept typical wheel weight on the inner or outer edge. In this case the mode of the balancing machice must be changed and taped weights used. They actually hold pretty good if applied to a clean surface.
If that's not the problem then I would look at the suspension and the brakes. when was the last time your brakes were serviced? It's very possible one of the slides is stuck, caused to edge of a pad to rub & warp a rotor which can cause a constant vibration. |
Re: Re: Re: Re: Re: vibration in steering wheel
![]() if thats my problem i will kill myself and honda employees, i have never replaced the brake pads or the disc. last time i checked (about 3 weeks ago) they said they are as good as new! i will check into that, thanks again everyone.
