Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-22-2004, 03:39 PM
MaximumGreen MaximumGreen is offline
Send a message via AIM to MaximumGreen Send a message via Yahoo to MaximumGreen
Hesistation caused by fuel injectors?
Hi, on my '95 SE (stick), the car hesistates during acceleration a little in an oscillating manner, as the engine goes through the RPM's. Like it will hesitate for just a brief moment at say 2500, then be okay til 3200, and so on. Has anyone else experienced this? Is it caused by something with the fuel injection?
Thanks,
Brian T.
Old 11-23-2004, 12:22 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Hesistation caused by fuel injectors?
check your pcv valve and fuel filter before you go through injectors. maybe you have a bad sparkplug. it could be a few different problems. did your car give a check engine light?
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 11-29-2004, 08:02 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Hesistation is caused by TPS. Sometimes.
Not a fuel injector:
Hesitation typically is due to whole engine (all cylinders) functioning improperly.
- If only one injector partially malfuntions (typically), power loss would be only say half of the 1/6 cyliders =5-15%.
- If ECU (the control box for all injectors) malfuntions, the it would affect all six, and hesitation would be total. --->ECU would also now have an error code -maybe.
- "the car hesistates ...through the RPM's" -points to a single source, sensor like TPS.
- Could also be fuel pressure reg. valve or fuelpump?
- Any sensor wire poor connection (affecting ECU)
My VG30E was like that:
- Cleaned all wirings, used also contact grease on all connectors (very little or less.
- Took all control tubing off one by one, cut 1/4 inch off from each and reinserted. (leakages due to brittled ends)
- Total Ignition wiring overhaul (old system)
- TPS Throttle position sensor was faulty. Repaired (buy new).
No hesitation after this.
Old 01-04-2005, 11:49 PM
Re: Hesistation is caused by TPS. Sometimes.
Here is a very late thank you for your reply! I will look into your suggestions. You know, I also get about 20-21 mpg on this '95 SE stickshift. 'Course, I drive about 80-90 too. But I wonder if that tells me anything.
Thanks again,
Brian
Old 01-05-2005, 11:22 AM
Re: Re: Hesistation is caused by TPS. Sometimes.
Thanks again,
Brian
VE -engine has coil packs on spark plugs, these are known to brittle causing spark high voltage leaks to ground. I would clean them and put some self vulganizing rubbertape on. If that does not help, they have to be replaced -might be expensive. Also install new plugs.
Have set up a web page for the maxima problems. Take a Lukiluki.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
