Old 11-22-2004, 03:15 PM
95xjsport 95xjsport is offline
Send a message via AIM to 95xjsport Send a message via Yahoo to 95xjsport
Power steering
The lower steering U joing has a black hose sitting against it that goes to the power steering fluid resevoir. The hose is worn probably about half way through, is this a bad thing? is the hose supposed to be up against it? I can't move the hose over because it conects like right there?? BWT 95 cherokee sport
Black 99 Jetta GLX VR6
Black 92 BMW 525I
Blue 95 GMC Jimmy SLT 4.3L VORTEC V6 (Sold... Junk)
Green 98 Jeep Cherokee SE (totaled Electrical fire)
Red 95 Jeep Cherokee Sport (Gone)
Green 93 Jeep Grand Cherokee Limited (for sale)
[email protected]
"Racing a ricer is just like competing in the special olympics, even if you win your still retarded"
Old 11-22-2004, 09:30 PM
cherokee_guy82 cherokee_guy82 is offline
Send a message via Yahoo to cherokee_guy82
I would highly suggest that you replace the hose as it is a fluid return hose and if worn completely through, can lead to losing fluid and damaging the pump. suggest to try to get a longer piece if it could be moved away from the steering, another thought would be that the pump is moved to tighten the belt. Is it streched to the point that the pump is closer to the shaft than it should be?
Old 11-22-2004, 10:20 PM
Re: Power steering
no, there is a connector on the steering box, where the hose plugs in, the hose is just against the u joint, I can't move to hose away because of the connector??
Old 11-24-2004, 11:49 PM
I guess that I don't have quite the same setup there
My steering pump moves in order to loosen or tighten the belt and from the looks of it, mine would do the same if I had to move the pump farther out. Would check to see if that is your problem and, if so, do you have the correct belt (ie. length)... That is just my guess there since I can't see what you are looking at. Does that help any, or still not close?
Old 11-25-2004, 09:06 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
I think this will fix it, first replace the hose, 25.00 at napa, hold the hose up out of harms way than fully tighting the two fittings, this should hold it up. I just replaced mine, hint..for more room at the bottom conection remove the airbox!!
Old 11-25-2004, 10:16 PM
Re: Power steering
My mistake, a close examination showed that the connector isn;t attached to the steering bix but, bent against it.
Black 92 BMW 525I
[email protected]
Old 12-09-2004, 03:55 PM
Hey 95, any idea what the line was for? still power steering or something else? (like the ricer thing!
Friends don't let friends drive ricers!
'99 Dodge Ram 1500 Laramie SLT
'04 Monte Carlo LS
Old 12-11-2004, 09:37 PM
Re: Power steering
lol, I like the ricer thing too... ya, I fixed it, I just bent it out some
Black 92 BMW 525I
[email protected]
Old 12-16-2004, 04:33 PM
Re: Power steering
glad you fixed it... Jeep On!!
'04 Monte Carlo LS
Old 12-17-2004, 11:53 PM
Re: Power steering
Thanks bro...
Black 92 BMW 525I
[email protected]
