Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-22-2004, 01:21 PM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
B16 problems, ITR piston issue
Hey,
I'm working on helping out a friend of mine who is building a B16. He has put ITR pistions in the motor, and when he turns it over, the pistons are coming out of the top of the bottom end.
He told me that he is using the factory B16 crank and rods. Any ideas as to whats going on? He wants to try and fix it by using a thicker headgasket, although I would say that's not a very good way to solve the problem
In any event, I'm just trying to get a little more information on what could have gone wrong.
Thanks,
-Jacob
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 11-22-2004, 01:38 PM
b18ls's Avatar
b18ls b18ls is offline
Banned
Re: B16 problems, ITR piston issue
A thicker gasket might make a small diff, but if the pistons are coming up as high as you said, it wont solve the problem. I would think the ITR pistons would fit with no Problem... Were they mounted correctly?
fISH...
Old 11-22-2004, 10:11 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
The reason they won't fit is because the deck height on an ITR is higher than a B16A2, and the ITR's stroke is longer to reach its deck's top.
B18C5 stroke=87.2mm
B16A2 stroke=77mm
Aves, how far are they sticking out of the block? My advice is for him to put the old pistons back in.
(fun facts of the day: ITR's and CTR's have the same deck height, but only a CTR's pistons are swappable with an Si and the ITR's aren't. A set of CTR pistons will raise the compression of an Si, and ITR pistons will lower it, simply because of the piston shape)
Old 11-23-2004, 10:30 AM
ridestreet84's Avatar
ridestreet84 ridestreet84 is offline
Send a message via MSN to ridestreet84
that is a very good fact of the day ric
Goodbye civic Hello turbo outback goodbye outback Hello WRX
