Ford Scorpio 5.0 Swap
I'm wondering how difficult it would be to cram a 5.0 Engine out of a Ford Mustang into a Scorpio. I know that the engine will fit without much modification to the engine compartment, but the biggest problem will be the wiring harness. I know there are a few people on the internet that made harness kits for the Ford Sierra to put a 5.0 in it, but does someone know how to do it in a Scorpio?
King Calibra 1992 Opel Calibra 1990 Ford Scorpio 2.0i http://www.cardomain.com/id/kingcalbira69 |
Re: Ford Scorpio 5.0 Swap
i've never even heard of a scorpio... but Painless performance sells a wiring harness kit for a 5.0/5.8 EFI motor that will hook right up and work with a computer you buy from Ford. then all you have to do is route the wiring neatly in your engine compartment.
as for engine transplants, anything can be done by somebody who has the correct resources.
-Andy '89 Mustang 5.0 - How fast? i'll know this weekend. '86 Mustang LX - Shortblock is built, now for the rest of it. "Put the subject before the verb, hmm? Fail this class, you will." -Yoda teaches english class. |
Just looking at the car it would be a lot of work and fabrication. You're better off buying a Fox body 5.0.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt. |
Re: Re: Ford Scorpio 5.0 Swap
![]() Everybody has a Fox 5.0, but how many people would expect it from a Scorpio? And I'm currently chatting with a guy that knows where to get a complete swap kit, so it won't be that bad....
actually look into if a 2.3t from a nother merkur will fit, i believe the merkur and the ford 2.3t (turbo coupes and svo) are the same motor. that would be a great swap
Go carb, wiring isn't nearly as much hassle. It's not like the thing would be very street legal anyway....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons..... http://www.cardomain.com/id/mccobra94 1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster. Freedom Isn't Free. |
As far as going carb, that's probably not a bad idea.... It would make wiring up the engine as simple as hooking up the sensors for the idiot lights.
I'm not looking for the easiest route, as this would probably be it. I'm looking for a pure, "what the hell do you have in that thing!?" reaction. I have the time and the patience to do it, so I'm opting for the 5.0 swap... Just because i doesn't happen very often...
I saw a couple with 2.9's in them over there, too, so maybe you could use motor swap mounts similar to those designed for a Ranger 302 swap?
