Old 11-22-2004, 11:22 AM
Magik Si's Avatar
Magik Si Magik Si is offline
Random...not starting!?!?
Hi guys/gals...
This is weird...early last week...my car had already been running...I made a quick stop somewhere, the car was off for maybe 2 minutes...and when i tried to start it again...no go. Everything had power, guage cluster, radio, heater fan...but when I turned the key to start...I got a series of rapid "clicking" noise and the dash lights dimmed (sounded like a battery dieing) and I stopped...I got a boost (which wasn't easy at 6:30am)...and was on my way...didn't do it again until this morning. Same thing...had been running for an hour and a half...shut it off for 5-10 minutes...no go...clicking...boost...no problem...I drove five minutes home, shut it off, and started it right back up again...started it an hour later again...no problem.
What the hell is going on!?
Only recent changes are O2 Sensor, Fuel Filter, Driver's Side Axle...HELP!
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 11-22-2004, 11:36 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Random...not starting!?!?
main relay?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-22-2004, 11:43 AM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
yeah check your main relay and your ignition coil. I have a bad main relay adn my car doesnt like starting when its hot inside the car, right after it stalls or is turned off, or basically when its been sitting in the heat for an hour.
1991 Honda Civic DX Sedan
Old 11-22-2004, 11:54 AM
Magik Si's Avatar
Re: Re: Random...not starting!?!?
I had a funny feeling you guys were gonna say MR...but I can still hear it "clicking"...I used to have that problem in my STD...but only when it was hot outside...the first time it was -8C and today it was 2C...so it wasn't too hot...plus this doesn't sound the same...at all. When I had a bad main relay before...the car would turn over, and over, and over...just dieing slowly...it didn't have this rapid freaky clicking associated with it??
Ignition Coil? Why does that sound expensive?
Jason
Old 11-22-2004, 12:08 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
not the starter?
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 11-22-2004, 12:38 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
boost means jump start? if that's what your car needs then it might be the battery not being able to charge or the alternator not being able to charge the battery.
Old 11-22-2004, 12:51 PM
Juicy05 Juicy05 is offline
yea i would guess that its your Alternator!
I had the same problem last winter...
Old 11-22-2004, 01:00 PM
Magik Si's Avatar
Boost = hooking up booster cables to another running car's battery and then starting my car...
Not the altenator...say it ain't so!
Jason
Old 11-22-2004, 01:05 PM
yeah just go to your local autozone, orielly's whatever you have around there, and they usually check to see what kind of voltage its putting out.... that should give you your answer. Also check all your grounds and clean your cables............good luck
Old 11-22-2004, 02:53 PM
cloneboy17's Avatar
cloneboy17 cloneboy17 is offline
my car was doing that and it was a bad connection on the top of the battery... get one of those post cleaner things.. like 3 or 4 bucks i think and clean it all up really good...... i had to replace the ends where the battery cable connects to the battery due to corrosion... if you have the fuses up there for the automatic seatbelts its a pain to replace the connector with the fuse assembly on it... not to mention expensive... i figured out a way to build my own fuse assebly so if u wanna know more lemme know... if you need to do that... good luck man.... sure sucks when your car wont start and youdont know why
Old 11-23-2004, 08:54 AM
Magik Si's Avatar
Ok...here's the latest update...
This morning (6:00am/dark out) my car was running and I jumped out to run into some place...when I came back out and got in the car I notice the gauge lights 'very' dim. So I shut the radio and heater off and they got a little brighter...when I accellerated they got a lot brighter but dimmed slightly when I stopped again...over the next 30 minutes of driving they got back to where they should be and I was able to turn the heater back on and the radio...got home...car off for about an hour...came out, started right up and everything was operating normally???
Could this be caused by anything you guys have suggested?
Jason
Old 11-23-2004, 09:31 AM
I had the same type of thing going on and it actually sorta went away. I thought I'd have to replace the battery for sure after one day I took a nap for an hour and left the lights on. The car started right up and I rode around through town in 3rd gear for 30 minutes and it was fine... that was like 8 months ago. I also had that Jacobs Ignition which draws extra juice (when car is running). You should play Sherlock Holmes and check for breaks in wiring basically everywhere. My car was bogging a bit in the rain the other day cuz a big SUV was rooster-tailing water all over my car and I'm sure I got some wires wet. I think I'm going to reloom the main harness for better protection. But, yeah, check your grounds and all connections... starter, battery, etc. It wouldn't hurt to have a parts place see what your voltage is putting out either. GL
2010 Honda CR-V EX
Old 11-23-2004, 10:46 AM
I would say just check your grounds an cable to the battery.. it could really be just about anything..... Any noticeable loss in power?
Old 11-23-2004, 10:59 AM
Magik Si's Avatar
Nope...nothing like that...just the dimming of the lights today, and the two times not starting? I'm baffled. (and also not good with all things electrical)
Jason
Old 11-25-2004, 02:35 AM
adaly86 adaly86 is offline
Hey mine was going that aswell, it cut out one morning though and wouldnt start, had to get it jump started, the next morning the same thing happened and for about a week it did it, brought it to the garage and they brought up the idle a bit, That following week was doing the same thing but the battery wasnt going dead anymore just kept cutting out, brought it back and they redid the whole carb and just gave it a full service, said the cause was that it was running lean, its been going fine since, it had them puzzled though for ages over it, first they tought it was electrics, not charging, bad altenator then they check the battery and leads but all was grand, anyway, its going great for me now!
