Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-22-2004, 11:18 AM
fatdubs fatman fatdubs fatman is offline
1992 3300 engine problem
1992 old cutlass ciera 3300engine 50,000miles. Car suddlenly stalls and has trouble restarting. Check engine light will come on and the fan turns on. While driving with diagnostic tool hooked up it seems to work fine for a bit. And then will run rough, check engine light will come on and it will looses connection thru the data port. Seems like it might almost be a grounding problem or electrical short. Please any help would be great.
the Fatman
[email protected]
Old 11-22-2004, 11:40 PM
bbudziszek bbudziszek is offline
Send a message via AIM to bbudziszek Send a message via MSN to bbudziszek
Re: 1992 3300 engine problem
hey buddy,
Have you check into your ignition system, your wires, spark plugs, DIS packs, igntion module? best bet is to start there before anythng else.
-Bob
Old 11-25-2004, 07:43 PM
djnoname djnoname is offline
Get your crankshaft pos sensor tested...
