Old 11-22-2004, 08:26 AM
Technical_Automan Technical_Automan is offline
Banned
Thumbs up Did a couple performance tests on my 94 SL
Because of a few unknown performance stats about the SL I decided to do a couple performance tests on my 94 SL...
- The first test was cornering. With the vehicle traveling at 65 MPH, I took an 80 degree turn. The front end slid for a slight moment, but then the back end broke loose (again just for a slight moment) and all tires gripped at the exact moment the car was straight. So for comparison sake, my 92 Integra had no slip on that turn at 65 MPH, but the slip of the SL was negligible.
- The second test was 0-60 MPH. From a dead stop I accelerated to 60 MPH with a couple chirps of the tires (so could be better), in under 6 seconds. I have yet to buy a stopwatch and have it timed by someone else for the EXACT time, but it is appoximately mid 5 to low 6 seconds.
Keep in mind the car has 93,000 miles on it and a 5-speed transmission.
Just thought i'd put my reckless driving to good use for once.
Old 11-22-2004, 08:45 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: Did a couple performance tests on my 94 SL
good stats. didnt realise the sl was that fast, have you done any more mods?
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 11-22-2004, 10:20 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Dam nice job bro, keep up them stats.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 11-22-2004, 12:38 PM
Banned
No mods, just swapped the tranny in there...I was told there is a Borla Catback on it when I bought it, but I can't tell from looking at it if the guy was just BS'ing me or not. Anyone know if the Borla says Borla on it anywhere?
Old 11-22-2004, 10:53 PM
Kev3000GT Kev3000GT is offline
Jack up the rear end and start looking. It should say it on the mufflers. Look at 3sxperformance.com's pic of the system to know where the name is branded on it.
Old 11-22-2004, 11:28 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
each mufler should only have one big tip if its Borla.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-24-2004, 12:17 AM
exterra3000gtsl exterra3000gtsl is offline
yeah, i think i seen the pic on 3sx and it has borla written in all mufflers....but damm good driving...what was you shiftpoint??
Old 11-24-2004, 04:25 AM
Banned
Thanks. From neutral I usually hold RPM between 3-4, and then let out the clutch smoothly but fast, and from there I always shift just before redline @ 6900 or so when i'm racing.
Old 11-24-2004, 03:19 PM
jdridah jdridah is offline
hmm i have to shift at 6000.. anything over that i lose power... weird. good stats though
__________________________________________________________
Old 11-24-2004, 04:40 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
you would be faster if you waited till redline
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-24-2004, 06:41 PM
Banned
Well over 6000 it feels like you're losing power and you are, but the higher you rev, the higher RPM you'll be at for the next gear so closer to your max HP (and it takes what .5 seconds between 6k and redline?), so it's faster the higher RPM you hit. I don't like hitting redline, just b/c my car isn't fast, it's quick, but not worth risking breaking or wearing the internals for. Once I get a fast car, and i'm racing for some cash, then i'll be goin all out.
