Old 11-22-2004, 07:54 AM
blucifixtion blucifixtion is offline
Send a message via Yahoo to blucifixtion
Exclamation Ac/heater Wont Blow!! Help!!
Ok, first of all, i got stuck in the mud in my yard. Of course I did the stupid thing and tried to get out...Finally got pulled out and I notice that my ac/heater/defrost no longer blows. I turn it on- NOTHING. I've checked fuses, doesn't seem to be the problem. Can anyone help me troubleshoot this? Btw, I'm a woman and only know how to drive and put gas in it. '97 cavalier.
Also- my check engine light stays on constantly and I've had the car looked at- no problem could be found.
Any help will be greatly appreciated!
Old 11-22-2004, 10:00 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Ac/heater Wont Blow!! Help!!
#1. When you say "I have no heat", please differentiate between "Cold air blows out of my vents" or "There is no air blowing altogether".
#2. If the case is "I have no heat", the cheapest and easiest first step is to replace the thermostat. If the thermostat is stuck in the open position, it will not allow the coolant to reach a hot enough temperature to produce heat. This is also a good time to check condition of the coolant, and flush/refill the system if it is questionable.
#3. If the thermostat has been replaced, check next to make sure your temperature control cable has not come unhooked from the back of the HVAC controls. If this happens, the air vents inside the dash will not shift properly, and one or more settings may be operating at the same time, adversly affecting vent temperature.
#4. If the thermostat is verified to be good, the coolant in good shape, and the HVAC controls operating properly, odds are, the cause is a plugged heater core. In this case, the heater core must be replaced, and it isn't a half bad idea to replace the heater hoses, since you're in the area.
Note: These diagnostic procedures are only valid if the vehicle is NOT overheating. If the vehicle is overheating and there is no heat, there is a different set of problems, and a standard overheating diagnosis should be taken instead.
Part I - The Air Conditioning System's Components
Most automotive air conditioning systems are made up of the same
components. By knowing what they are and how they work, you may be
able to save yourself a little time troubleshooting, or a few dollars
on a repair bill if you know what's going on ahead of time.
Freon: Freon is the refrigerant used in air conditioning systems. It's
purpose is to circulate through the system, transferring heat absorbed
by the evaporator (see below) and discharging that heat through the
condenser (see below).
For automotive usage, two types of freon have been used, designated
R-12 and R134a. R12 was the industry standard up until the years in
and between 1994 through 1996. Between these years, automakers were
told they had to switch from R-12 to R-134a, due to environmental
purposes. If your car is newer than 1996, it is 100% sure to be R134a.
If it is older than 1994, it is 99.9% sure to be R12. It is possible
to convert an R12 system to an R134a system, which will be discussed
later.
Compressor: The compressor is the heart of the air conditioning
system. It's purpose is to pressurize and circulate the freon. The
compressor is made up of two parts: the compressor body and the
clutch/coil/hub/bearing assembly.
The compressor body is the non-servicible rear portion that actually
does the compressing.
The front portion, which the drive belt runs on, is multiple pieces
and can be serviced individually if desired. The clutch portion is
responsible for engaging the compressor on and off. Contrary to
popular belief, the a/c compressor is not working 100% of the time the
belt is spinning, only whenever this clutch is engaged. The coil is
the electrical portion which determines when the clutch will engage
and disengage. The hub is the portion which the belt runs on, and the
bearing allows the assembly to freely rotate.
Condenser: The condenser is the large coiled assembly located in front
of your vehicle's radiator. It's function is similar to that of a
radiator as well. It removes the heat from the refrigerant, changing
it from a hot vapor to a warm liquid.
Evaporator: The evaporator core is the non-visible part of your air
conditioning system. It is located inside your passenger compartment,
usually in close proxemity to your heater core, and removes the heat
and humidity from the passenger compartment.
Expansion Valve - or - Oriface Tube: The expansion valve or oriface tube's job is to regulate pressures throughout the system. An air conditioning system will have one or the other. If it has an oriface tube as opposed to an expansion valve, the oriface tube acts as an additional system filter as well.
Accumulator - or - Reciever Drier: The accumulator's job is to remove moisture from the air conditioning system, and to also allow any sediments or contaminents to settle out. This item is the circular canister that is visible in the engine compartment.
Part II - Troubleshooting the Air Conditioning System
Now comes the part you all are probably wanting, what to do, check and have replaced or repaired if your air conditioning system stops cooling properly.
Step One: The first step is to make sure the system is full of freon. There are one or two pressure switches built into the air conditioning lines that will not allow the compressor to operate if system pressures get too high (caused by obstruction) or too low (low freon amounts).
The first step in examining freon levels is to have SOMEONE that has a set of professional air conditioning pressure gauges examine the current system's pressure. This is why I usually do not recommend one of the "fill it yourself" kits available from most retail stores. The reason is, these kits only include one pressure gauge, and a proper air conditioning diagnosis cannot be done without examining both the suction and discharge sides' pressures.
Once the pressures are determined, if the system is low on freon, recharge it. If the system is the older (R12) style of freon, it is recommended to retrofit it to use R134a freon, as R12 freon is quite costly compared to R134a. The retrofit procedure is done by completely evacuating the system of R12, replacing the service port fittings, and recharging the system with R134a. The use of an evacuation/recharge-machine-safe UV dye is recommended.
Once the system is recharged, check the system for leaks. This can be done with either a freon "sniffer", or with a black light if a UV dye has been added to the system.
If all the system needed was a recharge, and no obvious leaks are detected, the system should be operable. A recharge every now and then is considered normal, as a small amout of freon does start to seep out with age, as the various seals, gaskets and o-rings throughout the system begin to get brittle and lose their sealing ability. If you are needing to recharge the system as frequently as every other year, there is a leak that needs to be repaired.
If you recharge the system and the pressures on both gauges read in their normal levels, yet the system is still not cooling, the first thing to check is for proper compressor operation.
Usually, the compressor clutch is operated by a relay. Test to make sure that the compressor clutch is getting the correct voltages at the correct times. If not, there is an electrical problem that will have to be tracked down. If the voltages are ok, check to see if the clutch is either burned up or locked up. If this is the case, the recommended procedure is to buy a new or remanufactured clutch, coil, hub and bearing assembly, as it is wise to replace these as a set, for prevention's sake.
NOTE: Before any system componants are replaced, the system must be fully discharged of any refrigerant.
If the clutch is switching on and off correctly and is physically able to operate, check to make sure the compressor itself is not locked. Usually if the a/c drive belt was thrown off, this has already happened. If this has happened, the compressor will need to be replaced. If a compressor replacement must be done, it is wise to replace the accumulator, and if applicable, the oriface tube, as these act as system filters, and will not allow system contaminants to reach the new compressor. A parts store or repair shop will usually not warranty a compressor unless there is proof that the accumulator and oriface have been changed also. Compressors are available with or without a clutch assembly; I personally recommend buying only those compressors with a new clutch, once again, for prevention's sake.
If there is any other componant leaking, it must be replaced, or if absolutely neccesary, repaired.
One last situation is that the system is full to capacity, the compressor clutch is operating as it should, and the compressor is functional, but either the suction or discharge side pressures are not correct. This is usually the sign of a blockage somewhere within the system. It is advisable to replace the oriface tube if equipped, or to first replace the expansion valve, if equipped. If these items have been replaced once, and either the oriface tube becomes plugged again, the expansion valve becomes inoperable again, or the gauges still show incorrect pressures, this is either a sign of a restriction within a line, the evaporater or condenser, or a sign of impending compressor failure.
In any case, if a restriction is found, it is recommended to flush the system entirely, replacing whichever componants are unable to be flushed, and recharging. If restrictions continue to occur, it is usually the compressor coming apart internally, and compressor replacement must occur.
For those of you that read through all that, congratulations. You now know the basic operations of an automotive air conditioning system.
~~ Zliner from JBO
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 11-22-2004, 02:37 PM
Re: Re: Ac/heater Wont Blow!! Help!!
First of all, thank you very much for your reply! I'm taking it to the shop now.
Please read my original post: My ac/defrost/heater will not blow. I turn it on and NOTHING.
I'm pretty sure that even the title of this thread differientiates whether it's BLOWING or not.
Old 11-22-2004, 10:13 PM
Lifted GMT-360!
That was all a faq on another forum so i just put it all here for you
Old 11-23-2004, 10:07 PM
big dude1 big dude1 is offline
lol damn i was gonna suggest that your post be made a sticky because its very informative on the operation of AC and heating... i know a lot about both of those because i had to redo the system on 3 cars but for people that are curious its very informative
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
Old 11-23-2004, 10:22 PM
jerseycavyz24 jerseycavyz24 is offline
could also be ur blower relay, thats wut happened to mine. n those damn Gm techs still didnt fix it right, i hit a bump n it goes off
Old 11-23-2004, 10:58 PM
Lifted GMT-360!
Buy a haynes or chiltons repair manual for 14-18 bucks and save you self money... Do it yourself!
Old 06-27-2005, 12:34 PM
pincheyloveclaw pincheyloveclaw is offline
Send a message via Yahoo to pincheyloveclaw
Question Re: Re: Ac/heater Wont Blow!! Help!!
I've got a Chiltons Manual but it was awful nice of them to exclude the section on A/C. I bought my '95 cavi used and rebuilt. My compressor assembly was removed which I didn't mind until now because it doesn't suck engine power. but now its getting hot in MD and I'm originally from Maine so I'm not really a hot weather kinda guy. However, being from Maine I have never really worked on A/C so any advice would be helpful
does anyone have an exploded diagragm for a 2.2L compressor? Also, if I buy a Compressor/clutch will I still need a coil, a pulley, valves etc? (yes, I already know I need a new belt)? Also, I'm not sure how long the rest of the system has been 86 (I'm guessing about a year) so what kind of problems should I expect other than replacing the compressor? Is there an easy way to check for leaks before I dump freon into the system?
Mostly it just sucks that I have no component list or diagram so I'm not sure how many parts were removed along with the compressor.
