Old 11-22-2004, 01:55 AM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
I think its my water pump
ok,
I think my water pumps going out,
I here sqeaking at 2300 rpm & 4000 rpm,screaching !#!
doesn't sqeak when cold,
sqeaking on & off,while setting steady idel,
plus,I her some raddling noise coming from somewhere!
I replaced the alternator,3 different belts,made shore all bolts
was tightend,wd-40'ed some stuff,cant get it to go away,
so I'm replacing the water pump,
I had a good mechanic install one in front of me on my old motor,
d15b2,but now me & my brothers going to try it,on a d15b8,
I dont think its nothing,but just wanted to check up on some things,
about installing one,
would it be the same as a d15b2,90 civic? from a 92 cx?
& practicly just take off:
valve cover,timing belt cover,
mark where the timing belt was,
loosen the timing belt,
unbolt the water pump,
& reverse for installation?
thx for any help
In the process of B00stin my D
Old 11-22-2004, 03:37 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: I think its my water pump
Use a mother fucking period man. I know Etheopenas that can type better english than you.
Old 11-22-2004, 03:41 AM
Re: Re: I think its my water pump
l0l,thx
I know I need to work on that,
but thats not what I'm lookin' for
Old 11-22-2004, 01:51 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
sounds about right
just set it to top dead center and u wont have to mark the belt
Old 11-22-2004, 02:21 PM
thx,derek
Old 11-22-2004, 02:31 PM
BullShifter's Avatar
If the water pump got the t/belt the slightest bit wet REPLACE that to are you will be very sorry when she snaps. Valves crash into pistons and all types of damage may happen.
http://www.binghamtonlife.com/manual...es/91-10-7.jpg
http://www.binghamtonlife.com/manual...es/91-6-25.jpg
http://www.binghamtonlife.com/manual...es/91-6-26.jpg
http://www.binghamtonlife.com/manual...es/91-6-27.jpg
http://www.binghamtonlife.com/manual...es/91-6-28.jpg
http://www.binghamtonlife.com/manual...es/91-6-29.jpg
Getting the crank bolt off may be your big issue unless you have access to a high powered impact gun.
Old 11-22-2004, 06:15 PM
1PhatCX's Avatar
Originally Posted by 1990civicdxhb
thx,derek
no problem bud
