Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 11-21-2004, 11:22 PM
all4grog all4grog is offline
odd problem
hello all
It seems as though i have a problem. When i turn off the car the brake lights choose to stay on??? completely independant of anything i'm doing. usually with a hard press or two of the brake pedal they will turn off, thus allowing me to continue on without returning to a dead car.
i have no good idea what is causing this, maybe a bad sensor on the brake pedal, a bad fuse, honestly i'm pretty well lost on this one and work is rather hectic so bringing it to the shop would be rather inconvienent, so if at all possible i would like to fix it myself.
has anyone else had this problem, if so how did you fix it. If not any ideas???
for reference my car is a 2002 hyundai accent gs with about 20,000 miles on it. Thanks in advance.....
Old 12-05-2005, 10:14 PM
Melyssa Melyssa is offline
Re: odd problem
yep, I had this problem, I took it to the dealership to get it repaired and they said the switch just needed to be adjusted. fine.
here I am like three weeks later and it happens again. before I could lift the brake pedal out with the top of my foot and it turned off, but now it wont. I actually took out the brake light fuse for the night, because I have no way of fixing it myself.
Im really starting to think the dealership sold me a f**king lemon, and I am not pleased. apparently there is a hole in my front exhaust pipe (which they wont tell me the exact name of the part, just that it costs $300 to fix)
((these are two seperate dealerships -the one i bought from is in another city, and the one i get it fixed at is here where i live)_)
Old 12-05-2005, 11:26 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: odd problem
Get down in the floorboard, and look up at the brake pedal. There is a switch mounted on it. When the button is pushed in, the brake lights go out. All you'll have to do is loosen the switch, and move it towards the pedal until the brake lights go out, then tighten it back down..
Old 12-06-2005, 12:06 AM
inatalonIXLR8 inatalonIXLR8 is offline
Re: odd problem
TRY SPRAYING A LITTLE wd-40 ON THE SWITCH. IT SOUNDS LIKE IT'S STICKING.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 12-06-2005, 05:53 AM
Re: odd problem
lol, yeah...like i could do anything like that. i have no tools no nothin thanks though!
Re: odd problem
by the way, is it bad to take the fuse out and put it back in again?
Old 12-06-2005, 03:21 PM
Re: odd problem
No, pulling the fuse is OK. On some models, the brake light switch can be repositioned without tools...
Old 12-06-2005, 07:19 PM
Re: odd problem
No WD-40? Well maybe try a little cooking oil, or sex lube!
Old 12-06-2005, 07:59 PM
Re: Re: odd problem
I wonder if my brake switch will like the gentle warming sensation my lube gives them. ooo baby ! lol
Old 12-08-2005, 08:05 AM
Re: odd problem
Did anything work for you?
Old 12-08-2005, 11:51 AM
Re: odd problem
no , waiting for the dealership to get the part to replace it. $68 plus tax
Old 01-05-2006, 11:09 AM
Hyundai 1 Hyundai 1 is offline
Re: odd problem
i must admit amirican spec cars are a pain in the arse compared to brittish spec the switch for the break light cannot not be adjusted its just a pressure switch as in pedal down lights on pedal up lights off so i would get some wd40 spray oil spray it on the switch finger it a few times and that should sort it.
