Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-21-2004, 11:01 PM
TurboR850 TurboR850 is offline
Retard Timing runs lean or rich ?
Does retard the timing in any car cause the car to run lean or richer ?
Thanks
1997 850R
VMS Long Block
22 psi . . . 19T
So So So much more to list
Old 11-22-2004, 07:22 PM
caddycarlo caddycarlo is offline
as you advance the timing you will make better use of what fuel there is so as you retard the timing the motor will act like it is rich becouse it does not use the fuel as well ........ the mixture is controlled by the carb or fuel injection not the timing ..... but the motor will behave like it is rich or lean ...... also if a motor is running lean sometimes it will not take advance becouse it runs out of fuel ......
hope that was clear enough to help
