Old 11-21-2004, 09:21 PM
glock35ipsc glock35ipsc is offline
Heater blowing cold. HELP!!!
I can figure this thing out! It blows luke-warm at idle, and will get somewhat warmed at cruise speed, but then after driving for a bit then stopping, it is blowing very cool. I have burped the system several times, so I don't think I have an air bubble. Full of coolant, heater core is not plugged, both hoses are very hot right up to the firewall, but little to no heat.
My only thought it a door/flapper is hanging partialy open (or closed) and blending cold air from the outside. I have chased the vacuum lines the best I can, but still am scratching my head.
HELP!!
Old 11-22-2004, 05:50 AM
Cam7 Cam7 is offline
Check the door operation if they work probally check the thermostat if OK try this un hook the heater hoses and try to blow the heater core out with compressed air. Ive had this happen to me on 2 others. Same symptoms as yours.
Old 11-22-2004, 07:06 AM
I replaced the thermostat in the spring, so I ruled that out. I also did blow out the heater core, even filled it with hot water and blew it out, 1 gallon worth. As far as I can tell the doors are working normally, but I could be wrong there. Thanks!
Old 11-24-2004, 05:05 PM
tat2dbaldguy tat2dbaldguy is offline
make sure you have vacuum on the heater switches
Old 11-24-2004, 05:28 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
if hot water/coolant is moving correctly, your problems is in the door itself, the vacuum or the switch.
