Old 02-26-2002, 01:41 AM
vtecntrldSI vtecntrldSI is offline
raidiator question
how would u know if a radiator was workin well on my si hatch i wonder if its still workin cuz i bearly hear the thing turn on and somtimes my vtec valve cover is scorhchin hot! so just wanted to know.. civic experts reply with answer please.....
Old 02-26-2002, 06:00 AM
shorthand shorthand is offline
You know your radiator is working if the water temperature is correct. Do you have a water temperature gauge?
As for the valve cover getting hot - that's a bit of an odd description. It should get somewhat hot. On certain cars, that could be really hot. Is it hotter than it used to be?
The valve cover is in contact only with the oil. I guess its possible that oil temp could be up and the radiator still be working fine, but I can't imagine why.
A very cheap way to increase the effectiveness of your current raditor is to add a surfactant (a water wetter). Most part stores will have one. I use redline's in mine, not that it makes much difference in a new car, but I have noticed the water temp is a tad lower even in winter.
2000 Civic EX Sedan
Plum w/ tan racing stripes for speed
Si Rims
Bridgestone Potenza S-03 (195/50R15)
Rear Swaybar: Suspension Techniques 19mm
Strut Tower Bar: Neuspeed
Shocks: KYB AGX
Springs: Ground Control Coilovers (Not yet mounted)
72 STS
Photo by Carey Kriger
Old 02-26-2002, 10:17 AM
Rice-Rocketeer Rice-Rocketeer is offline
If your temp needle stays below half-way, don't worry about it.
Lookin at my gucci, it's about that time...
Old 02-26-2002, 10:32 AM
nemesls_2000's Avatar
nemesls_2000 nemesls_2000 is offline
Send a message via AIM to nemesls_2000
Come on now, don't tell all the "little secrets"......
Mods:
AEM intake, DC Sports 4-1 header, Tanabe exhaust w/ 2.5" custom piping, ITR exhaust cam, APEXi VAFC, AEM FPR, Warlboro 255l fp, RC 440 injectors, ACT stage 3 clutch, JR Supercharger, Weapon R coilovers, VIS CF vader hood, CF Angel Eye Projector headlights, Black housing corners w/ amber bulbs, "Hybrid" rear emblem, custom rear speaker panels.
Old 02-26-2002, 11:41 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
right dude, try touching my valve cover after i smash vtec to 7500 a couple times. you could cook a 16oz sirloin on it in 15 minutes. and factory water temp gauges are inaccurate to say the least. when i got my autometer water temp gauge i wanted to use the factory sender but i found out the thing only has 4 returns, something like cold, warm, operating temp, and meltdown. i never fully trust factory gauges except for the speedo. i think the only reason they are there is to put the normal user at ease. i doubt anythings wrong with your car at all. if your that concerned about it just sit there with the car idling for a minute or two, if the fan turns on your good, if it turns off after a minute then your good again.
Old 02-26-2002, 01:59 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Oh god Rick, love the new signature! Ahahahaa....
But yet, because your hood basically traps all your heat from the engine, ANYTHING under the hood will eventually get pretty hot and I wouldnt suggest putting your body parts in contact with it unless you are looking to burn on a "VTEC" mark into your skin
Your radiator still works when it holds fluid... if its empty, well how is it going to work? What could have happened though is a blown thermostat, a broken fan, something along those lines could cause your car to run hot (not sure if it is but im guessing) but like Rice-Rocketeer said... if your needle stays near half way you aint got nothing to worry about!
AF's Official Asshole
RIP AUNIE
Old 03-01-2002, 12:20 AM
jOYRiDe jOYRiDe is offline
wots 210 degrees farenheit in degrees celcius?? im stoopid, when i bought the water temp gauge, i bought the farenheit instead of celicus (im aussie )... is that temperature normal?? the needle usually sits on 180 deg F but also at 210.... should i get a larger radiator???
the radiator on the car right now looks like a single core and looks useless... im thinking of gettin a crx or lude radiator instead or maybe a better thermofan (if i put a/c back in)
Old 03-01-2002, 01:03 AM
200 F should be 100 Celcius. So it's a little over 100C. That's more than what it should be but not in the damaging zone. Your thermostat should open fully at 180 deg F and temps shouldn't go over 200 F. But hot days and "spirited" driving tend to slightly overwhelm the stock system. The rad isn't useless, it's just the bare minimum the car needs to not overheat itself. If you want to get a rad from another Honda, get a del Sol or Integra radiator. A better fan would be good but expensive. And getting a thermostat that opens at 160F would be good too.
Old 03-01-2002, 01:42 AM
thanks for the tip :bigthumbup
i might make a switch (or remove some wires) to have the fan blowing constantly....i dunno, decisions decisions
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
raidiater drain cock bigballs69 Mystique 0 08-29-2005 09:15 AM
raidiator drain plug The Strobe Ranger | Courier 2 04-21-2004 12:17 AM
