Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-21-2004, 08:46 PM
cchowus cchowus is offline
Send a message via MSN to cchowus
2000 Camry Headlight Aim
My car was in and accident and repaired with aftermarket "TYC" brand headlights. There does not appear to be a yaw (left/right) adjustment to aim these headlights. Did the factory lights have yaw adjustments? Does anyone have a method or work around to correctly aim these these headlamps? Thanks.
Old 11-21-2004, 09:06 PM
Cammy_01 Cammy_01 is offline
Re: 2000 Camry Headlight Aim
There should be an adjustment there somewhere on the light assembly I would imagine. I am not familiar with the Camry light adjustment.. on all the cars I have ever adjusted in the past there is an up and down adjustment, usually a bolt or screw and a left and right again with a bolt or screw with a spring on the other side. If there is not an adjustment somewhere which seems unlikely then the only thing I can think of to adjust the lights would be to carefully bend the headlight assembly to get close to where you need the adjustment to be.
Old 11-24-2004, 06:54 PM
Re: Re: 2000 Camry Headlight Aim
Cammy_01,
Thanks for they reply. I expected an adjustment mechanism too but none found! I may need to open the holes on the headlight assembly's mounting bracket to move it and get the beam into alignment. Was hoping to see if this was an issue experienced by others.
