Old 11-21-2004, 08:09 PM
hatchcivic hatchcivic is offline
Send a message via ICQ to hatchcivic Send a message via AIM to hatchcivic Send a message via Yahoo to hatchcivic
Temp Gauge
My temp gauge seems not to be working. A couple of minutes after I start my 88 hb civic the temp gauge goes from cold right to overheating hot. I know that the engine is not over heating not in a couple minutes. Also my gas gauge seems to be stuck. Anyone know what's going on. My check engine light is not on but my ecu flashed 6 times. any idea?
Old 11-21-2004, 08:47 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
Re: Temp Gauge
im having the same problem with my temp gauge too, but i didnt check the ecu... im not sure if this is true but i remember reading something about 88-91 crx have a recall or somthing on the temp gauge...
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 11-21-2004, 09:18 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Temp Gauge
code 6 is coolant temp. So you may have a bad sensor on the engine. Either that or your guage is messed up and causing the ecu to get false readings.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 11-21-2004, 10:36 PM
krustindumm's Avatar
krustindumm krustindumm is offline
Re: Temp Gauge
the engine and gauge have seperate sensors. check the wiring under the dizzy and the grounds in that area.
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 11-22-2004, 12:04 AM
Canabalooza Canabalooza is offline
Re: Temp Gauge
so if i was re-wireing my temp sensor wires and now it doesent work at all what would i have to change? my temp sensor? or the wire?
Old 11-22-2004, 05:54 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Temp Gauge
your temp sensor is grounding out somehow, it goes to hot when it touches ground.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 11-24-2004, 11:45 PM
Re: Temp Gauge
so uh... if its not doing anything at all then its not grounded but broken?
Old 11-25-2004, 12:42 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: Re: Temp Gauge
or unplugged
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-25-2004, 09:18 AM
i tried checking that the whole problem started when i rewired the plug plugged it back in and now it doesent work.
Old 12-05-2004, 07:15 PM
indianindian indianindian is offline
Re: Temp Gauge
My temp gauge has stopped working. It stays at cold. The engine doesnt seem to be getting overheated. It seems like I am not getting as hot air as I used to. The gauge worked a bit yesterday. I cant tell if its a gauge problem or if the thermostat is the culprit. Any troubleshooting help is appreciated. I have been driving my car as usual and cant feel/see anything suspicious. Thanks.
Old 12-26-2004, 12:41 PM
quewerks quewerks is offline
Re: Re: Temp Gauge
WASSUP....
I'm having the same problem as we speak.
To start, I'm going to the source. The gauge itself. Only problem here is that I'm not sure where the t-stat housing is located. I was told by almost everyone that it is located at the end of the top radiator hose to the engine block.....which it isn't.
Where is the damn thing!?!?!?!?
Old 12-26-2004, 11:01 PM
indian,
quewerks,
ZC stuff
Old 12-28-2004, 03:22 AM
Re: Temp Gauge
hey thanks for the pics, i didnt realize there was a little bitty connector right below the distributor the one with two wires puts on the code 6 CEL which is coolant temp so i figured it had something to do with that one but i was wrong. the wire broke off the sending connector for the guage and i put it back wala. all fixed. thanks again.
