tire pressure
does anyone know what the recommended tire pressure is for a 92 honda accord 4 dr sedan? made in japan if that matters
Re: tire pressure
35 psi on most stock tires.
Re: tire pressure
There should be a sticker in one of the front door jams, either on the frame or on the door, that has the recommended pressure...it should be on all cars.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: tire pressure
the reccomended pressure is between 35 and 36 psi....look at the driver side door jamb.
does that stay the same if i have 17" kumho tires on it?? my friend told me i should keep the front tires at 40psi because i use them for steering, and the back ones at 35. good idea or bad advice???
Re: tire pressure
bad idea......if you change tire pressure to be unequal your tires create drag and you loose gas mileage....if you were off roading then that is another story.
wow that was a really fast response!! anyways so i should go with 35 psi on all tires correct??
Re: tire pressure
go with what with your vehicle reccomends....
Re: tire pressure
If you have a different size tire on then the regular stock, the tire pressure can also be read from the tire itself. Just look around you'll find it. And keep all of the pressure the same on each tire.
aight thanks
