Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 11-21-2004, 07:57 PM
bond67 bond67 is offline
2000 mercury sable runs rough between 55-60 mph
Hi
I have a 2000 mercury sable with a 3.0. I have replaced the spark plugs, spark plug wires, the dpfe sensor & the egr valve. The vehicle still is idling rough and it surges @ 55-60 mph ( seems like it has a governor restricting it). It did not run like this when I purchased it. I have been to the dealer and they ran a diagnostics and told me it was the spark plugs and wires ( $60.00) and the check engine light came back on. I had it checked out at an independent repair shop (i was charged $45.00) and they said it was the dpfe sensor and the egr valve. I have changed all of the above parts with zero results! It all started when the battery went dead & i replaced the battery. Please HELP!!!
Old 12-11-2004, 05:55 PM
hughw hughw is offline
The next thing I would try is run a good enjecter cleaner through the fuel system...dirty enjecters shouldnt give a check engine light...but could cause the rough idle and surge
Old 12-13-2004, 01:45 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Did you check the alternator?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
