Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-21-2004, 03:19 PM
danlo_99 danlo_99 is offline
won't start/fuel gauge zero
So my daughters 2002 sc2 would not start. cranked fine. Turned key on and gas gauge showed no fuel and she said she had 1/2 tank? Put some fuel in throttle body, nothing. Checked for 12vdc at coil, OK. Pulled plug, no spark. Ah, must be crankcase position sensor, replaced it, no change. Noticed some corosion around positive post of battery, took it off, cleaned it, and car started right up. Now gas gauge also shows 1/2 tank. So moral of story is, it might crank, but it doesn't mean you have voltage. P.S. CPS is a stinker to get out!!!
Old 11-22-2004, 02:36 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Why didn't you check the battery first?
Old 11-22-2004, 08:29 PM
Re: won't start/fuel gauge zero
because the engine was turning over, so I knew the battery had to be ok
Old 11-23-2004, 04:07 PM
yeah but you said there was corrosion on the positive terminal. Was it that hard to spot? I mean it must have sucked that you changed a sensor for nothing especially since you said it was a pain in the rear.
Old 11-24-2004, 07:20 AM
yeah, I know, but being an old fart I assumed too much, "if it cranks you got juice" thanks again and have a Happy Bird Day!
