intake for 95 grand am se
Any body know where i can buy a cold air intake for a 95 grand am se? Or has built their own, like many pics i have seen, and can give me tips on how to? Any help is appriciated.
Re: intake for 95 grand am se
If you want to go really cheap you can use black ABS drain lines (plumbing pipe). Easy to cut, they make different angled elbows for them also. and all you need to buy is a cone filter for it. It ain't pretty, but if done right it's better than factory. I'm making mine out of carbon fibre next spring. To do this though you need to know how to make molds, work with composites and have access to a kiln. Plus, carbon fibre matting usually runs about 5X more expensive than it's fibreglass cousin.
Check ebay
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
www.summitracing.com and www.jegs.com both sell them but you would probably find a better deal on ebay or could save alot of money if you build your own. Good Luck.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
they dont make them for 2.3L Quad 4's. You can make them from ABS like forkliftguy said or even PVC pipe will work.
I looked on ebay and found some aftermarket intakes but i dont think their cold air intakes. I guess ill just buy that setup and then go find a cool air filter....
The reason a "cold air" intake is called that is because instead of drawing in warm air from the engine bay (which is what happens when you install an aftermarket intake, because the exposed filter element sits in the engine bay behind the battery), the filter element is located in the inner fender well outside of the engine bay instead where it draws in cold air. In reality, almost all stock intakes found in today's cars are cold air intakes because they are plumbed to the inner fender well. There is no such thing as a cool air filter. As I explained, the name comes from where the intake air is actually drawn from. HTH
Marc |
