Old 11-21-2004, 12:20 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
what headers do u use
okay ive found a place that will custom make my y pipe so i dont have to get the edelbrock headers, have any off u guys ever used hooker headers or headman headers. also did u have to fab anything like the ac braket like it says u might have too. what gaskets are good ones to use im sure the little paper ones that come w/ them suck and should i sand off the paint and coat it w/ high temp paint because i dont want to buy the ceramic coated ones thanx in advance
Old 11-21-2004, 07:58 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
hookers are good for old cars w/ lots of engine bay room(competition longtubes i mean) i personally have slp's on my car
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 11-21-2004, 11:40 PM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
i use flowtech full length they work very well but tight. 1 5/8 tubes 3" collector..lowering the car becomes an issue with them tho cuz well there low...
Old 11-22-2004, 11:22 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: what headers do u use
steer away from pacesetter. other than that i think you are on the right track, get better gaskets and coat em in something. it will save you in the long end.
*Better power-to-weight ratio than a C6 corvette*
Old 11-22-2004, 02:43 PM
LT1MAN LT1MAN is offline
Banned
YES!...STAY AWAY FROM PACESETTER!...BUNCH OF JUNK...high temp paint doesn't work either, everybody is going to tell you get ceramic get ceramic, its more expensive but you probably should, on my last set i paid 50 to have mine sandblasted and then i high temp painted them (1500 degree paint) and it all burned off in less than a week. but on this set i just said fuck it and put them on with nothing on there cause i drive it everyday, and they aint rustin yet...knock on wood
Old 11-22-2004, 03:44 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Black Jack
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 11-22-2004, 08:49 PM
i got a high temp silicone spay on coating from summit and its worked great so far. the thing about the high temp stuff is that you have to bake it in an oven to actually get the full effect. if you dont bake it, the stuff is only heat resistant up to like 500 degrees...
Old 11-22-2004, 09:00 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
edelbrock tes here.
Old 11-22-2004, 09:04 PM
ive heard good things about the edelbrocks...
Old 11-22-2004, 11:21 PM
is the high temp paint really that shitty? goddamnit i put that 1200 degree stuff on my headers, so i could skip out on coating them... i don't want to take that stuff off again...
Old 11-22-2004, 11:39 PM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
im gonna go with the RKSport ceramic coated headers.. only good ones i can find for the 3.4
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
