Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-21-2004, 11:59 AM
MS user MS user is offline
Send a message via ICQ to MS user
Can't start - need a help!
I have 00 Malibu for 4 years - I bought it a brand new.
Once or twise was a situation that the engine was "shut down", but every time it was start up normally.
Now, I was drive about an hour and then the engine just shut down.
Symptoms such as though gasoline has ended. Though the minimum 1/4 tanks still remained.
When I turn key ON - all the lights on control panel are blink and shiver.
Theft system light go OFF like normal after 2-3 sec. The starter turns normally.
But...There is no ignition.
Somebody know this picture?
Old 11-21-2004, 12:43 PM
goofy4467 goofy4467 is offline
Re: Can't start - need a help!
1. Is the theft light flashing after you try to start? if it is leave the key on for 10 minutes til the flashing quits.
2. When you turn the key on do you hear the fuel pump run and then shut off. It has to be quite to hear the pump run.. its in the fuel tank. My 2000 did this about 35,000 miles ago and it was the pump, It was towed in 3 times, the first 2 it started by the time it got to the dealer.
3. These years also are known to have fuel tank indication errors is there gas in it?
4. Does the car start for a second and then stop or does it not fire off at all?
Old 11-21-2004, 06:08 PM
Re: Re: Can't start - need a help!
[quote=goofy4467]
1. Is the theft light flashing after you try to start? - NO flashing (it's ON all the time when the key ON)
2. When you turn the key on do you hear the fuel pump run and then shut off. - do you mean that if NO SOUND then the pump no work?
End if it's run? what then?
3. These years also are known.... - it was fixed year ago and now I drive only Liter/Km, so I'm shure....
4. Does the car start for a second and then stop or does it not fire off at all? - It not fire off at all
Old 11-21-2004, 09:42 PM
what do you mean by this:
Old 11-22-2004, 03:02 AM
[quote=goofy4467]what do you mean by this:
I mean key ON position that switch stays ON when the engine is running.
When the engine is not running, we can use ON to operate electrical power accessories, and to display Instrument panel warning lights.Instrument panel - control panel.
So, warning lights come on when you turn the key to ON (but engine is not running) and stays ON
In my situation warning lights, gages and indicators are blink and shiver (gages).
