Old 11-21-2004, 11:58 AM
Technical_Automan Technical_Automan is offline
Banned
Angry Lifter Tick!! Nooooooooooooooo!!!
I've been dreading this day. I always read on here how some people are dealing with the annoying lifter tick and want the 99 lash adjusters. But I never had the problem...until today For the past week when I started up my car w/ the engine cold, I could hear the lifter tick for a few seconds, and then the oil would hit it and it went away. But this morning it didn't go away . So i've seen that an oil change takes care of it temporarily so i'll do that, but are there any additives that help?? like maybe that Lucas oil stuff, or the Castrol start-up protection. I've determined that start-up is what hurts our lifters, idk if that's been said but thats the obvious reason so I thought i'd be Captain Obvious.
Old 11-21-2004, 12:45 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Redline! Put that in there and it'll eleviate some to all of the ticking.
Resistance Is Futile (If < 1ohm)
Old 11-21-2004, 01:11 PM
Banned
Re: Lifter Tick!! Nooooooooooooooo!!!
I will try that thank you.
Old 11-21-2004, 03:10 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
what kinda oil are you using
Old 11-21-2004, 06:53 PM
Kev3000GT Kev3000GT is offline
hold on. I use Pennzoil 10W-30 every time with a stock Mitsu oil filter and I have lifter tick. But I can use ?Redline? and it will make some or all of it go away? Where do I buy this Redline of which you speak? The local Autozone, perhaps? Is it expensive? synthetic? b/c I was told that switching from non-synthetic to synthetic isn't good on high-mileage cars.
Old 11-21-2004, 07:07 PM
Banned
Right now i'm using 20W-50 Castrol GTX I believe...either that or penzoil, one of the two. As far as switching the synthetic everyone has a different opinion...if your car is a POS and you switch w/ high mileage, then it probably isnt good, but for a high performance sports car it would probably be fine. But no one has proved that it can be harmful or helpful yet that I know of.
Old 11-21-2004, 07:08 PM
Banned
Oh yeah and BTW the lifter tick went away again...but i'm sure it's just getting worse and worse with every cold start.
Old 11-21-2004, 11:24 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I'm starting to get it a little now that its colder outside and I switched to mobil 1 10W30 from what I think was non synthetic and no leaking or anything.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-21-2004, 11:33 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
why are you running 20-w50 when its cold out?
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-22-2004, 06:11 AM
Banned
I'm running 20W-50 because of 2 reasons:
1) This weather here is all screwed up, one day its 70, and then next it's snowing.
2) I haven't changed the oil to 10W-30 yet.
Old 11-22-2004, 06:44 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
I got it a couple of months ago too, its on and off. I deffenetly will change the lifters to the 99 ones soon. Oh and does anyone know how much the dealer might charge to change them???
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 11-22-2004, 11:37 AM
YogsVR4's Avatar
Re: Re: Lifter Tick!! Nooooooooooooooo!!!
Musashi - see the FAQ. It talks about the lifter replacement in there as well as $$$.
Redline is an oil treatment. It puts a coating on the internal parts of the engine which helps in getting the clogs out of the lifters (which is the source for the ticking sound). You can pick up a bottle at just about anyplace that sells motor oil (beyond a gas station).
Another alternative is to use a real lightweight oil. Run the car for a few days, drain that oil out and then put back in your regular oil. I've heard of this working.
As for switching to synthetic. There is nothing wrong with switching to synthetic at any time. The only time you'll have problems (potentially) is if you switch back to regular oil from the synthetics. Once you go synthetic - never go back.
Old 11-22-2004, 12:47 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Although the ticking noise might appear to get louder, nothing 'worse' is happening. Lifter tick will not harm your engine, it is just simply a very annoying sound. So don't spend too much time worrying.
I was quoted a price of $51.99 per lifter by Don Herring Mitsubishi in Plano, TX. That would put the price of a set of 24 at around $1200. So DO NOT go to the stealership for lifters. Rather, check the FAQ, there are 2 aftermarket options, and i've posted an addendum in the FAQ of 2 other places you can get 3rd gen lifters for a very fair price.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-22-2004, 12:50 PM
Banned
I've seen them on ebay for around $300 for the full set...and thanks I won't worry about it so much, I forgot it didn't really hurt anything...but i'm sure with every cold start there's a better chance the tick will want to stay around.
Old 11-22-2004, 05:34 PM
put some 5-w30 in and i bet it goes away.
