Old 11-21-2004, 09:09 AM
roger v roger v is offline
3.8 town country engine miss
I have a 2002 town /country 3.8 w/engine miss nnhas new plugs /wires and spark at all plugs. 150 lbs compression still has miss . any way to check injectors , or any idea asto problem ??
Old 11-21-2004, 04:47 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 3.8 town country engine miss
You could have a bad coil that is causing the problem. Also if you just changed the wires and plugs make sure that every plug wire is seated on the plugs properly. Had a problem with a T&C that I had with a loose plug wire. Looked seated but was just far enough off the plug to cause a miss.
Old 11-23-2004, 12:28 AM
Uncletg Uncletg is offline
Just had this problem with my 2004 T/C. It turned out that the #2 injector was bad. The fault code was PO302 (#2 cylinder misfire). PO301 would be #1 cylinder and so forth. Good luck.
