Old 11-21-2004, 01:13 AM
Automobile Maniac's Avatar
Automobile Maniac Automobile Maniac is offline
Question Someone please take a look at this GSX, should I risk it and buy it?
1996 Mitsubishi Eclipse GSX
Price $4995 (I talked them down to $4200)
Mileage 61565
Exterior Color Black
Interior Color gray leather (a little rough)
Body Style Hatchback
Doors Two Door
Engine 4 Cylinder Gasoline
Trans. Manual
Stereo N/A
Fuel Type Gasoline
Drive Type All wheel drive
VIN 4A3AL54FXTE400630
Carfax http://www.carfax.com/cfm/FSBO.cfm?r...FX000007872948
Notice the odometer rollback...? hmmm?
THE BAD
exterior a little rough---missing driver side moulding above ground effect (with bolt holes showing)---eagle talon swirl rims, with eagle center caps---all emblems ripped off of front, back etc...-stalls and keeps cutting off at idle---1st gear hard to engage---when hood is closed, you can move easily (like it would fly off going on the highway)---looks like it has had 3 different owners in one year's time
THE GOOD
big "wooshing" blow off valve---3" exhaust---no dents or scratches---the color black---it's a GSX!
Guy's/Gal's serously, should I risk it and buy it?????????
Old 11-21-2004, 01:50 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Someone please take a look at this GSX, should I risk it and buy it?
$4200 is extremely cheap for a 96 gsx with that low mileage! (even though there may have been an odometer roll-back). It seems a little suspicious, mainly because of the price. Ask the seller why exactly he is selling the car. Finding a 2g gsx with that kind of mileage for that cheap with a few problems sounds like a nightmare waiting to happen. I'd keep looking around if I were you.
And for what it's worth, my 95' gsx had 125k miles on it when I bought it: absolute mint condition inside and out, as well as mint mechanical condition and I paid $5200 for it! Just a heads up.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-21-2004, 03:13 AM
Scoped_GST Scoped_GST is offline
Send a message via AIM to Scoped_GST
i couldnt find any GSX's with under 50K miles (what i was looking for) for under 10K. If they were priced below 6K or so, they were either in bad condition, high mileage, or heavily modded with something wrong. Keep looking around for a real gem if you have to, and you wont regret it in the long run.
Old 11-21-2004, 04:27 PM
Re: Re: Someone please take a look at this GSX, should I risk it and buy it?
Thanks alot, also I forgot to mention it is at a car lot, they said it keeps stalling because they steam cleaned the engine (yeah right!). It also has a short thow shifter.
Old 11-21-2004, 11:35 PM
danameisoj danameisoj is offline
well from what i read the stall is coming from a vented bov... that would cause it to idle and stall... pop the hood to see if im right ... u never know... if not keep looking... i got my 95 gst running great and in mint for 3300.. u could always end up with a fwd.. but i perfer a awd as well good luck .. and let us know how your search ends!!
Old 11-21-2004, 11:42 PM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
suspicous to me
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 11-22-2004, 09:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
Good call on that one.
I would just make sure the basics are ok. If it passes a compression test, and the timing belt doesnt look too bad (Shoulve been replaced between 60-90k miles), the rest is usually an easy fix. The hard engagement to first gear is most likely just clutch hydraulics/bleeding. But at the same time I tend to be pretty lenient when it comes to this stuff because I can fix it all in my sleep. 4200 is cheap, and in my case worth the risk. My brother buys car with broken timing belts and such all the time because they go cheap, its an easy fix, and then you make some good cash. But it all depends on how much work you can do yourself, and wether or not you have a budget set aside for fxing any problems that arise. Another point I make is that the car could look the tits when you go to buy it, but then fall apart 1000 miles later. You just can't tell. Either way good luck
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-22-2004, 12:57 PM
Just want to say thanx to everybody, you have all been great. If I can talk them down any lower to maybe $3200 I will go for it (but I know thats not gonna happen!). Anyhow thanx again
