Old 11-20-2004, 11:59 PM
wkrice wkrice is offline
majior problems all at once?? help dear god help
93' honda accord
ok just changed my alternatyor for the second time battery light goes off and on oh yeah nd the cv is going out but thats another issue ..
ok battery light off and on now car wont start sounds like starter is not working and now the d4 light on my dash is blinking also have not had any problems starting the car until now going to attempt to change the starter motor but what about the d4 light blinking?????? any ideas
Old 11-21-2004, 04:04 PM
BlK_AcCoRd94 BlK_AcCoRd94 is offline
Re: majior problems all at once?? help dear god help
My d4 blinked also for a short time after i did a motor swap. It was a little sensor directly below the distributor and above the starter that was cracked. I pushed that back in and it quit doing it.
Old 11-21-2004, 05:51 PM
WhyteAccord WhyteAccord is offline
With that many problems, I suggest you take your car in for a regular tune-up and ask for a price quote and ask him what's wrong witht the car. When he tells you, take his suggestions and figure out how to fix it. He probably wont tell you how to fix it because that way, he wont be making any profit.
Old 11-22-2004, 03:57 PM
Mojeans69 Mojeans69 is offline
When you changed the alternator you did get a new belt correct??? It might be a worn out belt that just keeps slipping, even with a new belt it might be slipping in which you should check to see if the belt is tight enough and put a little belt dressing on there to get it gripping. That's what happened to me when I changed my alternator my belt wasn't tight enough and it just kept on slipping, which caused the battery light to come on. I tightened it up, and it was all set.
